Digital Posted August 19, 2012 Share Posted August 19, 2012 Will the MKIV-W58 gearbox fit onto a 1JZGTE-engine? If yes, do I need another clutch and flywheel or can I use the one from the MKIV-W58? Link to comment Share on other sites More sharing options...
Supra Gaz Posted August 19, 2012 Share Posted August 19, 2012 You can, its a well covered and moat awesome conversion, I believe you need a different bell housing for the gearbox. Search and you shall find all you need! Link to comment Share on other sites More sharing options...
keron Posted August 19, 2012 Share Posted August 19, 2012 mkiv w58 fits straight onto a 1jzgte.... uses the same clutch and flywheel as the w58. weve done a few now... nice conversion... Link to comment Share on other sites More sharing options...
Digital Posted August 19, 2012 Author Share Posted August 19, 2012 You can, its a well covered and moat awesome conversion, I believe you need a different bell housing for the gearbox. Search and you shall find all you need! I searched indeed. I understand that for a R154 you need a different bellhouse. My question is will a 1JZ engine fit in a MKIV nonturbo with existhing w58+clutch/flywheel? Edit: ok thanks Keron! Link to comment Share on other sites More sharing options...
neilthenut Posted August 19, 2012 Share Posted August 19, 2012 Will the MKIV-W58 gearbox fit onto a 1JZGTE-engine? If yes, do I need another clutch and flywheel or can I use the one from the MKIV-W58? staright on. see my project thread. Link to comment Share on other sites More sharing options...
