warning light problem update
Guest fitzy
Hey guys, this relates to the righthand side warning light module (oil pressure, oil level & check engine lights) Mine aren't working, so I discovered that by wiggling the wires that feed the push on connector, the lights come on. Does anyone know how to fix this? It seems the tiny spades aren't snugly fitting their other halves in the back of the warning light module. Ideas?
Hi SupraMan, can you be more specific? Exactly what needs soldering? Do I deposit a drop of solder on the end of each spade, or is it where the wires plug into the connector?
