Kaan's SRD1000S - 3.4 Stroked Wide Body Project!
Kaan W
  • Replies 2.6k
Posted Images
Amazing build this ...
Yea there is a thread in those brake lines .. Some people are really bad
Cheers yeah its a good job I had the car off the road when I did cause I doubt they would have lasted much longer.
Beast, Lee work is truly amazing!
Sure is bud.
Lee's just had delivery of a nice new 170 amp mechmen alternator for the build. Polished as well :)
http://www.mkivsupra.net/vbb/attachment.php?attachmentid=199187&d=1427147974
http://www.mkivsupra.net/vbb/attachment.php?attachmentid=199188&d=1427148015
Here are the ASNU 1600 injectors that I'm now going for as the 1100s will be at their limit out on ethanol. These will now max the turbo out and still have enough in them for more.
And they're silver ;)
http://www.mkivsupra.net/vbb/attachment.php?attachmentid=199354&d=1427476504
Nice move on those 1600 mate.
My 1100 were reaching their limit on 50% ethanol (89% DC). Those 1600 will give you enough room.
Yeah it's something we've needed to do, everything should be good for maximum potential of that turbo now.
What injectors are you running at the moment mate?
Getting closer to completion, oil cooler and lines are now all made up and installed -
http://www.mkivsupra.net/vbb/attachment.php?attachmentid=199453&d=1427899943
http://www.mkivsupra.net/vbb/attachment.php?attachmentid=199454&d=1427899962
So is the new 170 amp polished alternator and auxiliary belt -
http://www.mkivsupra.net/vbb/attachment.php?attachmentid=199451&d=1427899854
Looking good mate :thumbs: can't be that far off from actually getting to fire this beast up and hearing what she sounds like?
Cheers mate shouldn't be far off at all, gearbox and powersteering lines are also complete.
Engine is wired up, new 1600 injectors are also installed and the rest of the fuel system is now complete and working perfectly.
Main jobs now are finishing the brake lines and the relocation of everything that "was" in the bay and a few more little bits :)
The brake lines are now finished and completed after swapping to the LHD master cylinder, I wanted the braided lines hidden still so now they run under the booster and into the bulkhead instead of straight down and through like on other setups I've seen -
http://www.mkivsupra.net/vbb/attachment.php?attachmentid=199467&d=1428049363
http://www.mkivsupra.net/vbb/attachment.php?attachmentid=199468&d=1428049391
