Noz Posted August 18, 2012 Share Posted August 18, 2012 Just fitted new intercooler setup. Was going to fit the stock airbox back on and blow through some pressure to give it an extra clean out. Ive blasted it out with water, flushed the tubing and used clothes to get everything out after which I blew air into them but still not 100% as don#t want to risk anything. This shouldn't damage the turbo being disconnected I take it? Just wanted to check before I started flowing air Quote Link to comment Share on other sites More sharing options...
Guest ugp Posted August 18, 2012 Share Posted August 18, 2012 Just fitted new intercooler setup. Was going to fit the stock airbox back on and blow through some pressure to give it an extra clean out. Ive blasted it out with water, flushed the tubing and used clothes to get everything out after which I blew air into them but still not 100% as don#t want to risk anything. This shouldn't damage the turbo being disconnected I take it? Just wanted to check before I started flowing air Pull the pipe off the throttle body and fire it up..... Quote Link to comment Share on other sites More sharing options...
Lude Posted August 19, 2012 Share Posted August 19, 2012 Pull the pipe off the throttle body and fire it up..... What will that do? Quote Link to comment Share on other sites More sharing options...
David P Posted August 19, 2012 Share Posted August 19, 2012 What will that do? Give it a blow job! Quote Link to comment Share on other sites More sharing options...
Guest ugp Posted August 19, 2012 Share Posted August 19, 2012 Give it a blow job! You beat me to it Quote Link to comment Share on other sites More sharing options...
