Think I've Blown My Turbos
Big Mark
On a spirited drive home from seeing friends this afternoon I lost power.
The car is an auto RZ-S
My SBD id Bost Controller was already installed when I got the car and hadn't got around to reading up on it so left it set the same as when I got the car but I think it was set too high as afterwards I noticed that I'd hit 1.32 bar.
I've now got zero boost.
Any ideas how much this is going to cost to fix?
when you've found the blown hose and fixed it, turn the boost controller off and take it out and see what it boosts too, if it's lower than before then learn how to set the BC, if it's pretty much the same then the previous owner may not have installed a restrictor ring.
Thanks for the advice, will do!
Just had a look, couldn't see any blown off hoses but didn't check ones on intercooler. Definitely no rattles from turbos tho. Will pop it down to friendly garage in te morning.
Is it ok to drive as it is or shouldn't I?
If the intercooler pipr has blown off it will make a big bang and you will have no boost at all. Hope this helps :)
One of my pipes popped off when I removed it and didn't tighten the clamp enough on replacing it. It made a very loud 'whoosh' sound and when the boost gauge got past 0bar, it made a very loud whistle/whoosh. It also did it when revving while stood still.
If it's a stock SMIC, it's not too hard. If it's popped off the IC, you will have to take the drivers side wheel and arch liner off to get to it.
When one of my hoses was falling off I heard no pop or weird whistling sounds and my boost guage was still saying I was boosting fine but I lost loads of power and the acceleration was pathetic and felt like it was misfiring really badly. I think the turbos would be making a weird noise everytime you accelerated if they had gone.
Just back from having the car quickly looked at but none the wiser.
It looks like the actuator/wastegate (I don't know the difference) is stuck open as there is no boost being produced at all.
If I squeeze the main pipe from the turbos to intercooler and blip the throttle I can't feel any pressure at all, surely there should be?
You won't generate boost pressure at a standstill, atleast not enough to be noticable when trying to squeeze a hose. You might however hear a whooshing sound coming from the blown off pipe. In my opinion even if the wastegate was stuck open you'd still build boost as the stock wastegate can't flow enough to control boost at bpu (and certainly not at 1.3bar). What noise do youg et when revving it with the bonnet open? you'll be able to get a little boost with revving at standstill, enough to hear a blown hose.
