Geo Posted August 12, 2012 Share Posted August 12, 2012 As above, Anyone done this, and any special tools needed? Watched a few youtube vids, and looks easy enough, but wanted to know if the supra is different? Quote Link to comment Share on other sites More sharing options...
safcdixon Posted August 12, 2012 Share Posted August 12, 2012 Theres a faq thread on here dude cos i looked at it the other day because ive got a snapped stud on the rear EDIT http://www.mkivsupra.net/vbb/showthread.php?61142-How-To-Replace-a-rear-wheel-stud Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted August 12, 2012 Share Posted August 12, 2012 Hammer You will have to drill a hole in the backplate if you're fitting ARP's. As they are too long to go in without removing it or hole-ing it! If you don't need the extra length of the ARP's then get them turned down on a lathe and you will be able to pop 'em in without drill-age. Quote Link to comment Share on other sites More sharing options...
Geo Posted August 12, 2012 Author Share Posted August 12, 2012 found it, cheers guys Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 13, 2012 Share Posted August 13, 2012 NO NO, do NOT hammer them out, it bruises the hub bearings and you will probably have hub bearing noise / failure later. They should be pressed out, and pulled or pressed back in. Quote Link to comment Share on other sites More sharing options...
Wez Posted August 13, 2012 Share Posted August 13, 2012 I used a collection of hub pressing / removal tools to get them out, not too bad a job once you get going Quote Link to comment Share on other sites More sharing options...
Geo Posted August 13, 2012 Author Share Posted August 13, 2012 what tools to remove and press back in then? I'll got pick some up. Quote Link to comment Share on other sites More sharing options...
Wez Posted August 13, 2012 Share Posted August 13, 2012 I got some cheapo bits from Halfrauds. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 13, 2012 Share Posted August 13, 2012 I push them out wit a converted ball joint splitter, and pull them in with a plain full depth nut on top of a Torrington bearing, using moly grease. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted August 13, 2012 Share Posted August 13, 2012 i use a modded g clamp Quote Link to comment Share on other sites More sharing options...
tomgeer Posted August 13, 2012 Share Posted August 13, 2012 Use a ball joint splitter Geo, http://www.machinemart.co.uk/shop/product/details/cht222-ball-joint-remover?da=1&TC=SRC-ball joint, then use the wheel nuts and some washers to press the new ones into place! piece of piss Quote Link to comment Share on other sites More sharing options...
Geo Posted August 13, 2012 Author Share Posted August 13, 2012 Use a ball joint splitter Geo, http://www.machinemart.co.uk/shop/product/details/cht222-ball-joint-remover?da=1&TC=SRC-ball joint, then use the wheel nuts and some washers to press the new ones into place! piece of piss on it, Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted August 13, 2012 Share Posted August 13, 2012 what are you doing mate ? wheels spacer Quote Link to comment Share on other sites More sharing options...
Geo Posted August 13, 2012 Author Share Posted August 13, 2012 what are you doing mate ? wheels spacer broke a wheel stud when we had the wheel off, then back on. Doh!! Was tony's super duper strength Quote Link to comment Share on other sites More sharing options...
tony tt Posted August 13, 2012 Share Posted August 13, 2012 broke a wheel stud when we had the wheel off, then back on. Doh!! Was tony's super duper strength Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted August 13, 2012 Share Posted August 13, 2012 doh,, did you get a new stud sorted ?? i might have a spare in workshop Quote Link to comment Share on other sites More sharing options...
tony tt Posted August 13, 2012 Share Posted August 13, 2012 doh,, did you get a new stud sorted ?? i might have a spare in workshop I have a couple ordered Jurgen thank's anyway mate. Quote Link to comment Share on other sites More sharing options...
Gabriella Posted August 15, 2012 Share Posted August 15, 2012 ..and any special tools needed? tonytt? Very special very tool ..broke a wheel stud when we had the wheel off, then back on. Doh!! Was tony's super duper strength You ask for it didn't you? Quote Link to comment Share on other sites More sharing options...
