Guest optimus Posted August 12, 2012 Share Posted August 12, 2012 evening all,just wondered what the symptoms may be if the standard bov was failing.havent been full bpu for too long,but somethings not right. Quote Link to comment Share on other sites More sharing options...
Geo Posted August 12, 2012 Share Posted August 12, 2012 what do you think is up with it? symptoms? Quote Link to comment Share on other sites More sharing options...
Durandal Posted August 12, 2012 Share Posted August 12, 2012 When mine failed, it stuck open making it really hard for the turbos to spool and generally acting like a boost leak. Just take it off and see if you can blow through the big pipes. Quote Link to comment Share on other sites More sharing options...
Guest optimus Posted August 12, 2012 Share Posted August 12, 2012 (edited) hard to explain but yes seems to be hard work for turbos to spool,and it just feels like its struggling.the other thing is that if i floor it in 2nd it wont make a bar but then 1.2 in 3 4 5 6. but still feeling like its struggling. Thanks for that il try blowing down the pipes Edited August 12, 2012 by optimus (see edit history) Quote Link to comment Share on other sites More sharing options...
bodilx6 Posted August 13, 2012 Share Posted August 13, 2012 Also, you might experience the opposite. That it won't release pressure and you will get compressor stall with the well know ch-ch-ch sound. Do you build boost as you should? Quote Link to comment Share on other sites More sharing options...
Guest optimus Posted August 13, 2012 Share Posted August 13, 2012 (edited) thanks for responses,i think it makes boost ok,but i dont know anybody with one to compare it too.but other people talk about spinning wheels in 2nd yet mine wont and after building boost its almost asif that boost isnt then getting to the rear wheels if you know what i mean.but as i said floor it in 2nd and it only makes about .8 of a bar and falls off but then in 3rd makes 1.2 and holds it,but still seems like its hard work to spool up.have checked bov cant blow through pipes. Edited August 13, 2012 by optimus (see edit history) Quote Link to comment Share on other sites More sharing options...
Durandal Posted August 13, 2012 Share Posted August 13, 2012 I thought it was normal to have less boost in 1st and 2nd gear than say 3rd-6th. Quote Link to comment Share on other sites More sharing options...
bodilx6 Posted August 14, 2012 Share Posted August 14, 2012 That sounds about right. 1st and second usually dont go above 1 bar. Maybe if held in 2nd, don't remember. If you pull 1.2 bar in higher gears, and you don't hear a very loud ch-ch-ch sound, then all is well with your BOV. You shouldn't get wheel spin in 2nd unless its cold or you have crappy or very cold tyres. Quote Link to comment Share on other sites More sharing options...
CanisLupus Posted August 14, 2012 Share Posted August 14, 2012 Check your VSVs etc. of the sequential System. In Second it should get 1.2. First is often too short for the valves to open and start the second turbo. Quote Link to comment Share on other sites More sharing options...
