Removing doors?
Kaan W
How easy is it to bolt the doors back on after removing them and whats the best way to unbolt them? Just asking really as it will be alot easier for me to blend the skirts in with the doors off but have been told it takes ages to align them back up properly when bolting them back on. Anyone know?
Funnily enough I swapped a door only a few hours ago. Mind you I had the wing off too so I unbolted the hinge from the car, leaving it on the door. Pretty sure you need the wing to be off for this. I was able to libe the new door back up using the marks that the hinges left on the bodywork (sor of clean "shadows" in the accumulated muck. The door lined up on the second attempt.
I guess if you wanted to do this with the wings on you would have to open the door fully with someone or something taking the weight of the open end (I had a helper). Don't forget to disconnect the door check strap (like I did!) :)
Wiring blocks in the footwells, knock the pin out of the door stay and unbolt the four 12mm bolts on the back of the hinge (leaving the hinges on the car). The 4x 12mm bolts are self aligning, so no faffing around.
Hope that helps.
Hope that helps.
ohh crap wish i knew this before.
ive unclipped all the connectors inside the door and pushed all the wires through the hole and out the door that way, i thought the other end of the loom didnt have a block
:banghead::banghead::banghead:
took ages too
took ages too
And I was going to start this thread a couple of weeks ago.... Never mind mate we all learn from each others mistakes :)
