Brake Master Cylinder, Which One?
2soops
Was hoping someone may be able to help and provide a part number for a brake master cylinder.
My car started as a Jspec TT Auto, but is now a 6spd Manual. I am about to upgrade to UK brakes, and read on here the upgrade often leaves a spongy feeling brake pedal. I assume this is because of the extra pistons in the Uk set up, and slightly more fluid being required to push them out. I spoke to Toyota earlier about whether the UK brakes had a larger master cylinder for the extra pistons, and they confirmed there are 4 different part numbers for varying sizes/models/years. They couldn't however tell me which was the largest internal diameter.
Does anyone on here know a part number for the larger spec master cylinder so i can get one ordered, my car also has abs if that makes a difference.
Thanks for any help
Al
  • 1 month later...
