2jzgte clutch on r154 gearbox
skyludeboy
I did a lot of research about this for a 2jz swap into a landcruiser, anyway, they also use R series gear box and i found to make it work you obviously need the 1jz bell housing for the r154 but you need a 1jz clutch kit and fly as the 2jz is too big for the bell housing. I think the 7m one also as it used this box but defo 1jz clutch kit
