JDM TT brake swap to an J-spec N/A
Jamesc183
Front calipers, discs, brake pads and pad fitting kit.
Rear calipers, discs, brake pads and pad fitting kit.
They are a straight swap although as said you'll either need to trim, remove or replace the rear dust shield to allow clearance for the larger discs.
The larger brake calipers, particularly the fronts also need more wheel clearance between the back of the spokes and the front of the caliper.
