power steering 2jz - 1jz
mclarenross
I’m dropping a 1jzgte into my car this weekend and I don’t’ think I was supplied a reservoir for the power steering with this motor, so my mechanic has said I should just swap the one from my 2jz over. However the 2jz has the reservoir attached, (the 1jz doesn’t) has anyone else done this before?
Is the 2jz pump and reservoir a direct replacement or will the reservoir need modifying?
I have used the search on here and I know that they are the same pump, but I can't find any info on the reservoir.....
thanks!
