Dim Sum Posted August 8, 2012 Share Posted August 8, 2012 Just wondering if it is possible to buy adapters for the axle stand so the car can be lifted from the jacking points like the ones in the pictures. http://www.mkiv.com/manual/manualtt/vehicle_lift_and_support_locations/index.html Quote Link to comment Share on other sites More sharing options...
garethr Posted August 9, 2012 Share Posted August 9, 2012 (edited) In the USA, yes, but not in the UK (at least, I've not found any) http://protechproducts.com/index.php?route=product/category&path=40 Edited August 9, 2012 by garethr (see edit history) Quote Link to comment Share on other sites More sharing options...
SteveR Posted August 9, 2012 Share Posted August 9, 2012 A friend of mine has a business importing and cutting to shape all different types & strength of rubber. I'll ask him if he could do us a batch for a group buy. Quote Link to comment Share on other sites More sharing options...
listy Posted August 9, 2012 Share Posted August 9, 2012 A friend of mine has a business importing and cutting to shape all different types & strength of rubber. I'll ask him if he could do us a batch for a group buy. If he can I would be very interested Quote Link to comment Share on other sites More sharing options...
ManwithSupra Posted August 9, 2012 Share Posted August 9, 2012 Me too.. Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted August 9, 2012 Author Share Posted August 9, 2012 that be great. a set of four would be nice:) Quote Link to comment Share on other sites More sharing options...
stevie_b Posted August 9, 2012 Share Posted August 9, 2012 Good thread. From reading and asking questions on here, I gather that the sill jacking points are not the best places to jack the car up, possibly because the sill's protruding lip is liable to get crushed by the weight of the car pushing down on the OEM wheel jack. I'm guessing that the jacking areas on the sill are reinforced to take the car's weight over a small area (if not, it'd be a pretty rubbish jacking point!) So, I guess one of the requirements of the axle stand adapter is that it has a recess deep enough to prevent the lip being crushed: is that correct? Quote Link to comment Share on other sites More sharing options...
Dnk Posted August 9, 2012 Share Posted August 9, 2012 (edited) Something like this in hard nylon would do and would be very easy to make out of stock size nylon rectangular bar then machine the slot in and cut to required length Edited August 9, 2012 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
safcdixon Posted August 9, 2012 Share Posted August 9, 2012 These would be a great idea, my sills a flat in places were its been jacked up in the past! Quote Link to comment Share on other sites More sharing options...
Rajinder Posted August 9, 2012 Share Posted August 9, 2012 This what we have done. Welded a square tube with a cut. Works great. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted August 9, 2012 Share Posted August 9, 2012 Hockey pucks ftw. Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted August 9, 2012 Share Posted August 9, 2012 that be great. a set of four would be nice:) I'd take a set of three. No point in getting comfortable under there. Quote Link to comment Share on other sites More sharing options...
garethr Posted August 9, 2012 Share Posted August 9, 2012 (edited) Trolley jack as well. As Craig said, an ice hockey puck and a grinder works well for a trolley jack, although clearance might be a problem. You could easily knock something up in wood for the axle stands. The important thing is to straddle the seam and spread the load on the sill. Edited August 9, 2012 by garethr (see edit history) Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 9, 2012 Share Posted August 9, 2012 Personally I wouldn't want to be jacking up a near 20 year old car under the sills, nor putting axle stands there, either. You are far less likely to do damage by jacking under structural parts, or the rear diff, and supporting off the rear lower arms and the front cast allot X-member. The stock "jacking points" are probably created with the Americans in mind, many of which are far too fat to get down low to see and place anything further inboard Quote Link to comment Share on other sites More sharing options...
SteveR Posted August 9, 2012 Share Posted August 9, 2012 lol, apart from CW there seems to be a bit of interest in the idea of (very stiff) rubber or poly adaptors, I'll ask my mate whether he can do anything. Chris - I often jack off the diff or whatever but then I'm never that sure where I an use t support the car once I drop it back down - apart form the sill jacking points / tyre change points. What Dnk drew is the sort of basic design I had in mind; functional and hopefully easy (cheap) to produce. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted August 9, 2012 Share Posted August 9, 2012 I always jack under the diff and front cross member, but just inboard of the rear jacking point there's an area of fairly heavy duty structure, if I use axle stands I put them there. Quote Link to comment Share on other sites More sharing options...
Dnk Posted August 9, 2012 Share Posted August 9, 2012 Making them out of round nylon bar would be easier and cheaper by the looks of it, round nylon bar is readily available but to get rectangular pieces you'd probably have to buy it in sheet form and cut strips out of it adding to the cost. Quote Link to comment Share on other sites More sharing options...
merckx Posted August 9, 2012 Share Posted August 9, 2012 (edited) The stock "jacking points" are probably created with the Americans in mind, many of which are far too fat to get down low to see and place anything further inboard Probably. You are far less likely to do damage by jacking under structural parts, or the rear diff, and supporting off the rear lower arms and the front cast allot X-member. I always jack under the diff and front cross member, but just inboard of the rear jacking point there's an area of fairly heavy duty structure, if I use axle stands I put them there. Definitely, I've been removing the underseal back to bare metal under the car and so have had a good look at the structure underneath, the standard jacking points are nowhere near as strong as other locations further inboard. Edited August 9, 2012 by merckx (see edit history) Quote Link to comment Share on other sites More sharing options...
jonc Posted August 9, 2012 Share Posted August 9, 2012 Swampy442 I always jack under the diff and front cross member, but just inboard of the rear jacking point there's an area of fairly heavy duty structure, if I use axle stands I put them there. Me too that's exactly how I lift and support. I always lift the car on main structural points and put the axle stands on the heavy duty structure running along the floor pan. I always use wood pads between the jack and the car and the axle stands and the structure to keep metal to metal contact to a minimum Quote Link to comment Share on other sites More sharing options...
qwarrior Posted August 10, 2012 Share Posted August 10, 2012 I've got to admit, I never jack mine off the sills and as for "Axle" stands, it should be easy to guess where they're intended to support? Quote Link to comment Share on other sites More sharing options...
stevie_b Posted August 19, 2012 Share Posted August 19, 2012 I've got to admit, I never jack mine off the sills and as for "Axle" stands, it should be easy to guess where they're intended to support? Have you tried supporting the supra on its axles? Unless you're working on something like an old Series Land Rover, you'd probably need an alternative approach (I've not got much experience in this though so happy to be corrected). Since independent suspension and transaxles became the norm many years ago, axle stands can't easily be used on what passes as axles. CV shafts aren't load-bearing AFAIK, so I'm not sure they'd take kindly to be being used to support a car's weight. Even if they were, cross-members like on the front of the supra won't let you put an axle stand within a sniff of the axle. Quote Link to comment Share on other sites More sharing options...
