Radio Posted August 8, 2012 Share Posted August 8, 2012 (edited) I need to replace the receiver/drier unit on the air-con of my 95 UK TT as it is leaking. Has anyone done one before and advise me on the way to go about it. New part is ordered from toyota and is only £34. Cheers Ray Come on lads.........show me the light Edited August 9, 2012 by Radio (see edit history) Quote Link to comment Share on other sites More sharing options...
Radio Posted August 9, 2012 Author Share Posted August 9, 2012 Has no-one done this........... Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 9, 2012 Share Posted August 9, 2012 You just unbolt the pipes, unbiolt the bracket, and change it. You may need to add more compressor oil. It will need re-gassing and leak testing. If it's had mositure in it the system may become troublesome or fail again. I'd get an air con savvy speciaist to do it for you and then check the system pressures out. Personally i just open the windows Quote Link to comment Share on other sites More sharing options...
Radio Posted August 9, 2012 Author Share Posted August 9, 2012 Cheers Chris.........sent it in to be done and can be re-gassed again. Can you let me know your garage address/website as I had looked and could not find you. Handy to know when I need a valve stem ring replacement. Cheers ray Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 9, 2012 Share Posted August 9, 2012 SY13 2BT I don't have a web site, there's no point in generating more work than I can do, and the days of me employing people are done. Cheers ray. Phone number is in my sig below. Quote Link to comment Share on other sites More sharing options...
Radio Posted August 10, 2012 Author Share Posted August 10, 2012 Cheers Chris.......will be in touch when I need some work doing. regards ray Quote Link to comment Share on other sites More sharing options...
