bigbloodyturbo Posted August 7, 2012 Share Posted August 7, 2012 I suppose I should just leave this to my mapper but I'm interested in how this works. I got my syvecs s6 installed on Sunday and after a quick call to Ryan (thankyou very much for your help btw) I got over a few teething issues only to find my AFR's mental rich at idle. We had to pull fuelling right back from the base map that I got sent which was specific to sard 800's just to get it to idle. Now my injectors where bought from another member on here and were sold as sard/denso 880's but when they got flow tested and cleaned they came back at 800cc/min. Does anyone have any ideas as to why it would be pig rich? the only thing I can find is dead time that sard quote as 1.6 but my base map has been set at 0.9@12v. Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted August 7, 2012 Share Posted August 7, 2012 I have 800cc Sards in mine, mine ran mega rich on startup and did cause a problem when hot BUT ryan soon sorted it out in 5 mins by pugging the laptop into the syvecs. Its is very common that the Sards leak past there seals i have been told Quote Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted August 7, 2012 Author Share Posted August 7, 2012 I'm sure the mapper will be able to do something about it it's just i'm interested to know what the issue would be. I replaced all the seals when fitting them to my rail (new seals on pintle end, new orings above the inlet screen and new anti-vibration orings, surely if it was leaking past the seals it would pool in the intake and I would get surging from time to time. Do you remember what you set your injector dead time to? Quote Link to comment Share on other sites More sharing options...
Eki Posted March 9, 2014 Share Posted March 9, 2014 Hi.Did you ever get that injector dead time sorted yourself?I've bought some denso 880cc high imp blue top feed injectors that I'm not sure of what to think. Now I'm trying to set them up for power fc but its a fing pain...help? Quote Link to comment Share on other sites More sharing options...
