safcdixon Posted August 6, 2012 Share Posted August 6, 2012 Hey guys im gonna bpu my tt over the next week or two so im needing a boost gauge, i have a blitz one fitted (but not wired up) the boost pressure sensor is double the price of what a new depo boost gauge is and i cant justify paying £120 for a sensor! now i Know you get what you pay for but does anyone have experience with depo gauges? Good or bad, before i go ahead and buy one Or does anyone have a blitz boost pressure sensor going spare? Link to comment Share on other sites More sharing options...
listy Posted August 6, 2012 Share Posted August 6, 2012 This has been covered before. I think a few people use them and have no problems. Just can't remember who lol Link to comment Share on other sites More sharing options...
ripped_fear Posted August 6, 2012 Share Posted August 6, 2012 Yeah this has been covered before and alot of people said they where using them with no problem at all, but some did question there accuracy. Link to comment Share on other sites More sharing options...
safcdixon Posted August 6, 2012 Author Share Posted August 6, 2012 If thats the general feeling that they are fine then great because at that price they are a steel il wait and see if anyone with a one fitted chimes in Cheers guys Link to comment Share on other sites More sharing options...
p3te Posted August 6, 2012 Share Posted August 6, 2012 I bought. The full set but sent them back after fitting the boost gauge, at 1.27 bar it was showing nearly 1.4, they also felt cheap and they wered the easiest to see Link to comment Share on other sites More sharing options...
safcdixon Posted August 6, 2012 Author Share Posted August 6, 2012 I bought. The full set but sent them back after fitting the boost gauge, at 1.27 bar it was showing nearly 1.4, they also felt cheap and they wered the easiest to see Never! Ive have literally just purchased one off an ebay seller, i knew i should have waited but stuff it if it reads wrong il send it back, how were they when you wanted too return them did they argue or just give you a refund? http://www.ebay.co.uk/itm/120867761296?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649 thats the type ive just bought Link to comment Share on other sites More sharing options...
p3te Posted August 6, 2012 Share Posted August 6, 2012 I had the 7 colour electronic series and I bought mine off prolex-uk, they were fine sending back the new unfitted ones but the boost gauge I had fitted I just stuck it on ebay Link to comment Share on other sites More sharing options...
safcdixon Posted August 6, 2012 Author Share Posted August 6, 2012 I had the 7 colour electronic series and I bought mine off prolex-uk, they were fine sending back the new unfitted ones but the boost gauge I had fitted I just stuck it on ebay Ok Nobother pete hopefully mine will read correctly and hopefully il have no problems with it Link to comment Share on other sites More sharing options...
spikedjack Posted August 6, 2012 Share Posted August 6, 2012 i dont know about anyone else, but i just read off of my profec B II for boost pressure as its easier to read peak pressure than on a gauge at full chat Link to comment Share on other sites More sharing options...
safcdixon Posted August 6, 2012 Author Share Posted August 6, 2012 i dont know about anyone else, but i just read off of my profec B II for boost pressure as its easier to read peak pressure than on a gauge at full chat I thought i read that a boost controller wasnt nessesary at bpu? does it show you peak boost after youve let off the throttle like? Link to comment Share on other sites More sharing options...
spikedjack Posted August 6, 2012 Share Posted August 6, 2012 I thought i read that a boost controller wasnt nessesary at bpu? does it show you peak boost after youve let off the throttle like? that it does, you can run an RR at BPU and use the EBC to increase the boost and spool time above that of the RR Link to comment Share on other sites More sharing options...
Supra N_A Posted August 6, 2012 Share Posted August 6, 2012 there awesome gauges tbh.. heres mine VERY accurate Link to comment Share on other sites More sharing options...
safcdixon Posted August 6, 2012 Author Share Posted August 6, 2012 there awesome gauges tbh.. heres mine VERY accurate http://i287.photobucket.com/albums/ll124/ashleightroup1988/DSCF0714.jpg Do you only have the one mate or do you have any of the others? Im wanting one more too fill the vent in on the drivers window side, what do you guys suggest the other gauge be? Egt? Link to comment Share on other sites More sharing options...
sideexitsupra Posted August 6, 2012 Share Posted August 6, 2012 (edited) As spiked jack said, I also use my boost controller. Safer to have the restrictor ring at something 1.1 bar and use the boost controller to get to 1.2 Greedy Profec B 2 is what I have. As far as other Gauges go I have an AFR coming and will be adding EGT, water temp, oil temp and oil pressure. Just need to work out where the EGT will go as want to keep my vents. AFR in place of the clock, with oil and water under the stereo. Have seen pictures of a gauge below the ciggy lighter before, so that may be where the EGT goes. Was looking at a screen to do all but will probably have to go with budget gauges for now. Edited August 6, 2012 by sideexitsupra (see edit history) Link to comment Share on other sites More sharing options...
safcdixon Posted August 6, 2012 Author Share Posted August 6, 2012 I have just bought a 1.2bar r/r so i should be ok for raisng boost aslong as i dont get any creep, If i do il look into a 1.0bar r/r and a boost controller, fingers crossed it will hold steady at 1.2 Link to comment Share on other sites More sharing options...
