Is autobahn88 1st decat pipe any good?
rallly
I would of thought performance wise the only difference would be the dimensional width of the pipe. The wider the pipe the better flow your get. The manufacture will usually just give a difference in product quality.
Being a 3" pipe your pretty safe with that item your not gong to be restrictive up to well over BPU levels.
With a wider pipe, or different manufacture the chances of lowering performance are slim. Obviously with a smaller pipe say, 2.5" you may reduce the BPU potential.
The general say-so is 3" exhaust for up to 700hp, different opinions are knocking about depending on who you talk to. Obviously the wider the exhaust the better flow your get.
Is there such thing as too big? Like in terms of not enough back pressure?
Just what I needed to read ^^
Might be a silly question, but how will my exhaust guy join my 3" dp to a 2.5"midpipe? I'm sure there is a coupler for this but just wondering in-case I gotta purchase some special part for him.
Got it fitted on my TT6...
Straight fit, no hassles, car runs as a BPU should..
Recommended...
Had one fitted when i was bpu, mechanic moaned that it didn't line up with the trans mounted exhaust bracket but that could've been him being pedantic so he could charge more. Worked very well although it did rust so is not stainless but the flanges all lined up with no issues.
Mine went on no problem, bolted up to the OEM bracket as well and is definitely stainless steel..
  • 2 weeks later...
What mates to the autobahn88 dp?
The Supra has 2 catalytic convertors as pictured below, the short one nearest the engine connects to the turbos, then there's the 2nd larger catalytic convertor, this then connects to the cat back exhaust. The autobahn88 decat pipe in your link replaces the first cat.
Standard 1st and 2nd catalytic convertors
Stock cats next to decat pipes
