tooquicktostop Posted August 6, 2012 Share Posted August 6, 2012 The car goes into garage whifbitz at the end of the month to have a single kit fitted as well as a new high flow fuel system, before that the car goes to Dave for new coilovers and a big brake kit fitted Question is I want to do this properly and have taken some key learns from previous mistakes I have made, some of them costly as well, I have brought an oil cooler and twin kenlowe fan set up, I have since been thinking perhaps I am better sticking with the stock fan (fluidyne rad) ? I also read that an oil cooler lowers oil pressure which I don't see as a smart move, would you leave the fan as stock and not fit the oil cooler Link to comment Share on other sites More sharing options...
sdistc Posted August 6, 2012 Share Posted August 6, 2012 Main reason for fitting the electric fans was space considerations - they don't necessarily outperform a (new) clutch fan, but with a bigger aftermarket radiator there often is too little room for it. Link to comment Share on other sites More sharing options...
johnny g Posted August 6, 2012 Share Posted August 6, 2012 I've got an SRD rad and stock fan/shroud, plenty of room there, Dean. Chris Wilson was saying the stock fan is perfectly fine, might sap 3-5bhp though!! Link to comment Share on other sites More sharing options...
Luxluc Posted August 6, 2012 Share Posted August 6, 2012 I've got a big PWR rad with stock fan/shroud. No problem at all. I wouldn't change the fans unless you want a cosmetic upgrade of the engine compartment. A big rad is more than enough. Link to comment Share on other sites More sharing options...
Kaan W Posted August 6, 2012 Share Posted August 6, 2012 Im changing to a twin electric fan simply because the viscous fan is ugly. I would think the bigger alloy rads would help cooling even if the electric fans suck less cfm over stock but im no expert. Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted August 6, 2012 Share Posted August 6, 2012 Get a SRD Fan kit! perfect setup mate and worth every penny Link to comment Share on other sites More sharing options...
mellonman Posted August 6, 2012 Share Posted August 6, 2012 i tell you what is a smart mod is to make sure that you get a cold air feed for the air filter its amazing how much heat soak they get from that bay Link to comment Share on other sites More sharing options...
