Oil Temp
SupraJames
Just a quick question concerning oil temp, roughly what temp should oil be on 70 mph ish motorway driving, not really on boost and around 2500-3000 rpm. Car is a UK Spec auto not sure how this would affect it but I have recently fitted an ali rad, twin fan setup and a trans cooler also with a fan on and since fitting my oil temp seems to be much higher on motorway drives.
Yep same, I have a sandwich plate between the filter and block with oil temp and pressure senders in it, 110 seems a bit high for my liking.
Chatting to Lee earlier we think the issue is the new ali shroud the twin fan set-up is mounted on, it is blocking the air flow threw the rad when the fans are not on, before looking at a new shroud or changing the fans etc etc, going to try the cheapest option of modifying the current set-up by improving the air flow threw the rad, prob by ducting or adding some air flow holes in the shroud.
