HELP NEEDED. Exhaust bolt needed
kniff_666
Need some help quickly.
Just taken off my exhaust manifold and 1st cat. Noticed that one of the cat to manifold bolts was not tightened all the way because it's cross threaded! Pissed off now cuz it needs sorting or my exhaust will blow. Anyone got a bolt like the one in the picture below that I can have today?
Similar thing happened to me, I just replaced it with a bolt of the same dimensions rather then a stud and nut
any issues with it coming loose? (what with the vibration and the constant temp changes)
Can you use "loctite" on the bolts for the exhaust system?
been done about 5 weeks now without issue, i just coated it in copperslip to make sure it wouldnt corrode up again, as with all of the others i put in
OK. Nice tip that.
Just out of wanting to be completely sure about the bolt size i need.
Is it an M10x1.25 bolt that i need? (hopefully still fresh in your memory?)
