Is my tyre safe?
hogmaw
The Supra was pulling hard to the left today and when I stopped the front left tyre looked quite flat, I went to the garage and it was only 10psi. Will this have damaged the tyre so much that I will need a new one? I'm a bit wary of going to a garage to ask because they bound to say I do even if I don't just so they can have my £300 for a new one; a lot of money of course, which I'd rather keep in my wallet.
You might not see much damage from the outside, might be better taking tyre off rim and checking inside. Usually if it is damaged you will see lots of black rubbery 'dust' rolling about inside.
What size of tyres you got?
Probably about 10-15 miles, I can see some wear on the sides where it must have made contact with the road
Thats quite a distance on a very low pressure so i'd guess it must have deformed the
sidewalls quite a lot and the lips of the rim tend to cut into them. Get the tyre popped off
so you can have a look inside.
I think i'd play safe tbh and get a new one
