propper way of running 12v fuel pumps
dr_jekyll
If you are running stock ECU then you wont be able to remove the fuel pump ecu. This is due to the Fuel pump ecu giving a digital signal back to the engine ecu to tell it that the fuel pump is running.
If you are running aftermarket management, then you can replace it with a relay. You simply use the power in to the fuel pump ecu as relay power in. The output to the fuel pump from the fuel pump ecu as the relay out. Then use one of the other wires, I think the green one from memory, from the fuel pump ecu as a trigger wire, triggered by the aftermarket ECU. The green one runs to the footwell by the ECU. Is your ecu capable of giving negative outputs? The easiest way to do it is to assign the fuel pump to a negative out from the ECU, connected to the green wire, to trigger the relay. Obviously you will need a positive half of the trigger system. Simply T off from the power in to the fuel pump ecu. :)
It's a pretty easy job. Use the live an earth from the pump ECU to a 12v relay switch terminal. Take a constant 12v from the battery to the relay and 12v out to the pump. Make sure you earth the pump to the chassis with the same AWG cable the live is.
