Sharpie Posted August 10, 2005 Share Posted August 10, 2005 Hi, I'd like to add a 'watermark' just like in this MVP photo but, can't seem to find a option to make the text clear (ish). Any pointers ? (Have PS 7.0.1 btw) Ta Quote Link to comment Share on other sites More sharing options...
Trig Posted August 10, 2005 Share Posted August 10, 2005 Try changing the opacity of the text, should be one of the boxes on the layers box. hth Quote Link to comment Share on other sites More sharing options...
Shovels Posted August 10, 2005 Share Posted August 10, 2005 In PS one of the text tools will type for you as a selection tool, it's the 'T' with dotted lines all the way around it. Use this to type what you want the watermark to say. Then press and hold down 'ctrl' and tap 'j' - This will create a new layer from the selection (the text) On the new layer you can then double click and add effects like bevel and emboss. This should give you the appearnace of a watermark. Quote Link to comment Share on other sites More sharing options...
