kniff_666 Posted August 2, 2012 Share Posted August 2, 2012 Hello guys, Just wanted to know if you guys know what the would be the optimum wheel alignment (suspension) settings for my supra. I would like the optimum setup for normal road driving (with a bit of "spirited" driving where safe) and very little tire wear. (still needs to be fun to drive) Currently i am running 18" AVS Model 7 alloys (not sure on the offsets) staggered setup. looking at toe-in, camber etc. (full 3d alignment) Any help much appreciated (saw a thread on here that was related to alignment for track days also). Quote Link to comment Share on other sites More sharing options...
Guigsy Posted August 2, 2012 Share Posted August 2, 2012 (edited) The place aligning it should know. If they don't, go elsewhere. When I get mine done they ask what I use the car for and I just say a bit of drag racing but even wair and rear grip would be nice as I drive it as often as I can. Then they just do it. If your wanting specific toe and camber settings for racing your not going to be getting good ware on the tyres. So if it's normal driving then I'd imagine the normal Toyota settings are fine. It's a sports car after all. So the stock settings are usually quite good for handleing. Plus all the hours Toyota put into finding the settings. Edited August 2, 2012 by Guigsy (see edit history) Quote Link to comment Share on other sites More sharing options...
-Welsh-Stealth- Posted August 2, 2012 Share Posted August 2, 2012 Throw in a search should be plenty of threads on it. Was one recently with loads of different set ups on it. Have Mr T's settings if you need them Quote Link to comment Share on other sites More sharing options...
JMB Posted August 5, 2012 Share Posted August 5, 2012 http://www.supraforums.com.au/forum/a80-mkiv-discussion/60023-mkiv-wheel-alignment-specs.html Quote Link to comment Share on other sites More sharing options...
Nic Posted August 6, 2012 Share Posted August 6, 2012 http://www.turbosupras.com/pdfs/JZA80%20TSRM/SA.pdf http://mkiv.com/techarticles/lance_alignment/index.html Quote Link to comment Share on other sites More sharing options...
kniff_666 Posted August 6, 2012 Author Share Posted August 6, 2012 thanks guys. as ever; you guys come up with the goods:d Quote Link to comment Share on other sites More sharing options...
bodilx6 Posted August 6, 2012 Share Posted August 6, 2012 +1 for nic Quote Link to comment Share on other sites More sharing options...
