kniff_666 Posted July 31, 2012 Share Posted July 31, 2012 This should be a simple question to answer but i can't find the answer anywhere. What size of sump plug washer do i need for the 2jzge engine. (from a 94' SZ-R manual)? A quick response would be appreciated. (in the process of procuring one ready for a good self service this weekend) Quote Link to comment Share on other sites More sharing options...
kniff_666 Posted July 31, 2012 Author Share Posted July 31, 2012 And also if someone knows the sizes of the following: - drain plug gasket for the TORSEN LSD - drain plug gasket for the manual gearbox (5 speed) Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted July 31, 2012 Share Posted July 31, 2012 Sump plug is 12mm. I recommend a snug fitting dowty/bonded washer for this situation. Great sealing without massive strain on the treads. I can't help you with the others but they may be ok to reuse anyway. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted July 31, 2012 Share Posted July 31, 2012 Mate serously, go to Toyota with your chassis number, they cost like a quid or something. Quote Link to comment Share on other sites More sharing options...
Digsy Posted July 31, 2012 Share Posted July 31, 2012 Don't you get one free with the (£8) OEM oil filter? Quote Link to comment Share on other sites More sharing options...
Guest Budz86 Posted July 31, 2012 Share Posted July 31, 2012 Yep Quote Link to comment Share on other sites More sharing options...
kniff_666 Posted August 1, 2012 Author Share Posted August 1, 2012 Ok i get the point guys but my local toyota parts dealer is not exactly local. Rather than driving all the way to the dealer to get the £1 part while using £20 worth of fuel i was thinking of ordering over this wonderful thing called the interweb. £1 plus free postage makes more sense. Does anyone have the part number for the Diff drain gasket? Quote Link to comment Share on other sites More sharing options...
Digsy Posted August 1, 2012 Share Posted August 1, 2012 You could buy 100 to make it more cost effective My Toyota dealership are unusually helpful and used to mail parts out. Not sure if they still do. Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted August 1, 2012 Share Posted August 1, 2012 Does anyone have the part number for the Diff drain gasket? Engine Sump Plug Gasket: 90430-12031 Gearbox Drain & Filler/Level Plug Gaskets: 90430-18008 (x2) Differential Drain & Filler/Level Plug Gaskets: 12157-10010 (x2) Quote Link to comment Share on other sites More sharing options...
kniff_666 Posted August 1, 2012 Author Share Posted August 1, 2012 Thanks for the help guys. Quote Link to comment Share on other sites More sharing options...
