Tee from China Posted July 29, 2012 Share Posted July 29, 2012 Whilst surfing the other day I found a nice Supra in Japan with rear tyres that have that 'stretched' look as if the tyres are too narrow and the rim is exposed to kerbing. The size quoted is 11 x 19 on 265/30 x19 - wouldnt 295's or bigger more suitable or do people actually like that look? Quote Link to comment Share on other sites More sharing options...
JamieP Posted July 29, 2012 Share Posted July 29, 2012 295 would be better, my front wheels are 11x18 with a 265 tyre, I had to go with a small stretch to clear the front arch. Quote Link to comment Share on other sites More sharing options...
Kaan W Posted July 29, 2012 Share Posted July 29, 2012 (edited) Its funny I was going to make a thread about this the other day. I keep seeing this lately and thought prehaps people just got the wrong tire for wheel but as it happens its no mistake. I really cant get my head around this as the reason for a wide wheel is to get more rubber to the ground right? Why are people getting drawn in to this new wierd craze??????? Im sorry but I just think it looks riduculous tbh. Edited July 29, 2012 by Kaan W (see edit history) Quote Link to comment Share on other sites More sharing options...
dan294 Posted July 29, 2012 Share Posted July 29, 2012 A small stretch looks cool, but that is just ridiculous! Quote Link to comment Share on other sites More sharing options...
sdistc Posted July 29, 2012 Share Posted July 29, 2012 (edited) Tyre size does depend a little on the manufacturer - the same sizes are bigger or smaller between brands, for some strange reason. For 11" width, 305 or 315 is indicated, but again, depending on the brand, 295-315 might fit without stretch or bulge. Edited July 29, 2012 by sdistc (see edit history) Quote Link to comment Share on other sites More sharing options...
JamieP Posted July 29, 2012 Share Posted July 29, 2012 My 265 on a 11" wide wheel dont look much of a stretch to me, tyre still protects the rim from curbing. Quote Link to comment Share on other sites More sharing options...
dan294 Posted July 29, 2012 Share Posted July 29, 2012 Yours looks spot on Jamie Looks miles better with those facelift front lights as well! Quote Link to comment Share on other sites More sharing options...
Luxluc Posted July 29, 2012 Share Posted July 29, 2012 I would go for 305 on a 11" rim . Quote Link to comment Share on other sites More sharing options...
Tee from China Posted July 30, 2012 Author Share Posted July 30, 2012 http://i1097.photobucket.com/albums/g351/kaan2lee/realfitmentbi5.jpg Im sorry but I just think it looks riduculous tbh. That just looks stupid! Wonder what effect it would have on the tyre bead? Compared to that the Supra in Japan doesn't look that bad in comparison! Quote Link to comment Share on other sites More sharing options...
Mario Posted July 30, 2012 Share Posted July 30, 2012 (edited) I think it looks weird too, but there is actually a reason for it too, http://driftjapan.com/blog/car-parts/drifting-hipari-style-tires/ In Japan, the word Hipari refers to a tire style that is achieved by stretching a narrow tire over a wider wheel like a 215 35 18 inch tire on a 9.5 wide wheel. The difference in widths causes the sidewalls to stretch from the lip to the tread giving the tire a unique low profile stance and increased sidewall rigidity. In drifting, less sidewall flex means smoother weight transitions, improved throttle response, better steering feel, and less body roll when cornering. There are higher end tires that can provide these same handling characteristics when drifting without the sidewall stretch, but they are expensive and herein lies another advantage of the hipari style tire – narrow tires are cheap. Stretching a thin tire onto a wide rim decreases a wheel’s standard tire width resulting in a smaller contact patch and less traction. When learning how to drift this can be advantageous since you can get the car sliding sideways at lower speeds. However in pro level drifting events, drifters need as much traction as possible out of their tires to control their drift cars at 100+ mph so initially it seems that hipari tire would not be the best choice but pro drifters found a solution. D1 Grand Prix drifters get around the traction loss issue by using super wide wheels that fit tires they would usually use on their car so the overall contact patch stays the same. This gives the hipari look without loosing traction. Stretched tires can be used on all four corners of a car but up front, usually you don’t stretch the tires to the same extent as they are stretched on the back. For example, a car with 8.5 inch wide wheels all around, would use 210-220 tires up front and 195-205 tires in the rear. This gives the drift car good grip up front for steering while maintaining the hipari style and handling advantages. Another thing to note is that stretched tires require a higher psi than normal. 40+ psi is recommend for stretched tires. The history behind hipari style stretched tires is two fold as poor people have been stretching tires onto wheels they don’t belong forever while euro tuners in Germany and Belgium started stretching their tires out of legal necessity. Local laws there require that the tire tread be within the fender line and with wider or lower offset wheels that can cause problems. To maintain the wide wheel fashion and keep the car street legal, narrow tires are stretched over the wide wheels. Popular Tires for Stretching: Toyo T1-S Dunlop SP9000 Dunlop SP8080E Falken FK451 Other tires will work. Find a tire with a rounded shoulder and lip protector. If you want to get the tire outside the fender, use wheel spacers. Most wheel and tire shops will be willing to stretch tires and it will take a professional air compressor to help seat the tire as it can take up to 90lbs of pressure to pop the bead. Critics of the hipari tire style say it’s all about fashion and anything that reduces a car’s contact patch is dumb. Some go further to say that stretching tires increases wear because of uneven heat dissipation and that may increase the potential of tire failure. As far as safety goes, there is little evidence that stretched tires are any more dangerous than regular tires. One problem though is that your wheels are closer to street and damaging potholes but you should stay away from holes in the ground anyway! Edited July 31, 2012 by Mario faulty link (see edit history) Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted July 30, 2012 Share Posted July 30, 2012 Local laws there require that the tire tread be within the fender line and with wider or lower offset wheels that can cause problems Same rules apply in the UK Quote Link to comment Share on other sites More sharing options...
Mario Posted July 31, 2012 Share Posted July 31, 2012 Swampy442Same rules apply in the UK ^^Oke, think the same applies down here. Quote Link to comment Share on other sites More sharing options...
