r2ck_p Posted July 28, 2012 Share Posted July 28, 2012 Hi, any idea how easy it is to take the external door handles off? Could go with getting them sprayed. I assume its a door card off jobby ? Cheers Quote Link to comment Share on other sites More sharing options...
listy Posted July 28, 2012 Share Posted July 28, 2012 IIRC I think so. Quote Link to comment Share on other sites More sharing options...
Supra Gaz Posted July 28, 2012 Share Posted July 28, 2012 Yup, door cars off dude, it isn't too hard, if I find any pics I took when I took mine off I will post them up on here. Quote Link to comment Share on other sites More sharing options...
jay200bhp Posted July 28, 2012 Share Posted July 28, 2012 theres a hole underneath the window rubber this allows you to access the 10mm bolts with extension bar and socket once window is up the lock mechanism will pull through the hole in the door once the two bolts afore mentioned are removed, unplug the lighting loom and then manoevre the lock barrel through its arpeture .you will have to remove the catch connecting rod next by squeezing the two tabs that lock it to the barrel with pliers id tape around the door handle so you dont mark the door paintwork...happy days Quote Link to comment Share on other sites More sharing options...
