oem flywheel bolts
skyludeboy
Hi mate!
I've got a Twin Plate myself from Exedy and the manual tells you which bolts to use for it ;)
As i wasn't 100% sure(it stated to use the 2jz-ge shorter bolts) i asked Exedy directly and got the following response:
Good Morning,
I have contacted EXEDY Japan and have found that you should actually use 90910-02103 as per the manual. 90910-02115 is long-type bolt and 90910-02103 is short-type bolt which should be used with TM042SD.
Apologies for the confusion.
Ordered them and works a treat :)
