R Black Posted July 27, 2012 Share Posted July 27, 2012 (edited) I recently, swapped over my tailgate for a better one, anyhow apart from the fact all that glass makes it all very heavy, the only thing left to swap over, is where the rear wiper goes the big nut, and the driveplate That connects to the wiper motor. Any tips or just be brutal, doesn't matter about the tailgate its on. Edited July 27, 2012 by Gaz6002 title adjusted (see edit history) Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted July 27, 2012 Share Posted July 27, 2012 I've changed your title to reflect what you're actually asking. It makes it easier for others to find this thread in the future, and makes people more likely to help you out. Try a bit harder next time Quote Link to comment Share on other sites More sharing options...
JakeG Posted July 27, 2012 Share Posted July 27, 2012 Take the wiper arm off first then you can remove the big nut(think its a 28 iirc) then remove the pastic cover inside of the bootlid, and there will be 3 bolts holding the wiper motor in place, disconect any wires and your done Quote Link to comment Share on other sites More sharing options...
R Black Posted July 27, 2012 Author Share Posted July 27, 2012 Thanks Gaz. Hi Jake u have a boot lid with just the nut and the driveplate under it, not much to grip from the underside to allow me to get the nut off. Would it be easier with the motor attached, didn't think that would hold it, as its very tight. Quote Link to comment Share on other sites More sharing options...
