Drift Bears Project Zeus
drift_bear
I haven't done a search yet, but what ethanol % is in the meth?
On the other hand, ethanol is less chemically toxic than methanol, and it carries more energy per gallon. Ethanol contains about 75 percent of the energy of gasoline per gallon, compared to 67 percent for methanol. Both thus achieve fewer miles per gallon than gasoline, but about as many miles per dollar at current prices, and probably many more miles per dollar at future prices.
Methanol is more corrosive than ethanol. This can be dealt with by using appropriate materials in the automobile fuel system. A fuel system made acceptable for methanol use will also be fine for ethanol or pure gasoline.
Both ethanol and methanol are water soluble and biodegradable in the environment. The consequences of a spill of either would be much less than that of petroleum products. If the Exxon Valdez had been carrying either of these fuels instead of oil, the environmental impact caused by its demise would have been negligible.
Both are 109RON. Methanol bears more oxygen than ethanol, allows for a richer mixture and has a lower vaporisation point. It has more heat dissipation than ethanol too.
:thumbs:
  • Replies 2.4k
Posted Images
Thats pretty good for a bpu car, does it have an EGT sensor? Be nice to know what they was.
It had an egt temp gauge in when I first got the car, I removed it a few months ago cause i removed the A pillar pod it was in and it looked like a cheap style of gauge. The sensor is still there to be used with the syvecs though
As Alex said we are using Methanol because of the availability and price.
We wont be using as much of a mixture but will give very similar results.
Ethanol will be better for you Luc as you should be able to get it at the pumps.
Just out of interest, as this has hybrid turbo's, has anyone ever ran ethanol / methanol on a Bpu car with stock twins? And if you could would there be any real gains to be had by doing this. Might be another option for us stock twin Bpu guys.
Not 100% sure tbh, I know some people have used Meth water injection kits which helps to cool charge temps but we are actually mapping for it as well so the gains should be good.
It would work just as well on a stock turbo car but you would be limited on boost with the J spec turbos
You would need to be running a Syvecs to have this function though
Thought I would do an updated spec list (at last) and have put all the new parts in red to make it easier for myself just now lol
Engine Specifications:
• Q45 90mm Throttle Body
• Asnu 1000cc Injectors
• Denso iridium grade 9 spark plugs
• Battery Relocated to boot
• Wire tuck and tidy up
• Blitz LM FMIC
• Blitz dump valve
• Engine oil cooler kit
• Greddy oil cap
• HKS speed delimiter
• HKS Cams
• Supra etched stainless FMIC cover
• Stainless fuse box cover
• Polished manifold covers
• Polished turbo pipe
• Stainless radiator plate
• Chromed radiator clamps
• House techniques silicone hoses
• TRD chrome strut brace
Turbocharger & Induction:
• Turbo technics large steel hybrid turbos (rated to 1.6bar/23psi)
• Blitz SUS air intake filter
Fuel & ECU:
• 044 Bosch fuel pump
• Top Feed Fuel Rail Kit
• Fuel Flex Sensor
• Aeromotive FPR and lines
• Syvecs Ecu
• Supra Adapter Harness
• All syvecs sensors
Fuel Type
• V-Power
• Methanol
Exhaust:
• SRD Intake Manifold Kit
• Blitz nur spec R
• Chris wilson downpipe
Drivetrain:
• V161 Getrag 6 speed gearbox
• Stage 1 clutch
Suspension, Wheels, Tires & Brakes:
• 19" wheelmania vortex R (8.5" et 35 fronts , 9.5" et 35 rears)
• Toyota bilstein yellow shocks
• AP 6 pot front brake callipers
• AP 356x36mm front brake disks
• Goodridge braided bake lines
• OEM Uk spec rear callipers
• OEM Uk spec Rear disks and pads (have got spare disks/pads to go with the car aswell)
Interior & ICE:
• Toucan Display
• Uprated speakers all round (makes to be confirmed)
• Recaro seats
• Bride RO sub frames
• Isotta evoluzione steering wheel
• Levoc carbon gear selector
• Chrome speedo bezels
• MOMO handbrake
• Pioneer mp3/ipod/bluetooth single din head unit
Exterior:
• Top secret carbon bonnet with aerocatches
• Top secret front bumper
• Bomex side skirts (genuine)
• OEM facelift headlights
• OEM facelift rear lights
• OEM facelift indicator and sidelights
• Ridox carbon roof spoiler (genuine)
• Do luck rear bumper
• Do luck 3D carbon rear wing (genuine)
• Vented front wings
Performance
• 455.8hp @ 1.4bar (flywheel) - Before the above work in red is started
Edited by drift_bear (see edit history)
Roger that Lee.
Good luck mate. Impressive figures on the hybrids. What was the torque at 1.4 bar Alex?
- - - Updated - - -
Roger that Lee.
Not to sure bud, will get lee to put them down. I was only sent the figure lol
