Jellybean Posted July 25, 2012 Share Posted July 25, 2012 https://www.youtube.com/watch?v=q6I6_CVw16A&feature=youtube_gdata_player Link to comment Share on other sites More sharing options...
Jellybean Posted July 25, 2012 Author Share Posted July 25, 2012 I have a triple plate clutch in her , maybe that is the ticking ; hardly the injectors ticking or is turbo fubar Link to comment Share on other sites More sharing options...
tkddav3 Posted July 25, 2012 Share Posted July 25, 2012 doesnt sound like a clutch? but im not exactly what you'd call an expert Link to comment Share on other sites More sharing options...
Ian C Posted July 26, 2012 Share Posted July 26, 2012 I see a lot of threads like this in tech and it's a bit annoying when we have to ask a shedload of questions before we can start helping, like: 1) when did this start happening - today, always, last week when you dropped a screwdriver bit down the oil filler cap? 2) Under what conditions does it make the noise - cold, warm, all the time? 3) What's changed on the car recently - clutch install, different oil after a service, news cams, it's been stood for 3 years and just been started...? Help us to help you -Ian Link to comment Share on other sites More sharing options...
Jellybean Posted July 26, 2012 Author Share Posted July 26, 2012 Sorry Ian It all spans oiff this Thread , you helped me with http://www.mkivsupra.net/vbb/showthread.php?273756-fuel-regulator-vacuum-pipe-jspec Re-plumbed in the Idle air reference hose for EVAP system; Engine light and she smells of overfueling Error codes 31 -- Air flow meter Circuit short 34 -- Turbo Pressure Malfunction;short in VSV or waste Gate Circuit I disconnected the Idle air reference hose for EVAP system and Engine light is gone, she sounds OK ; no strong petrol fumes from exhaust Obviously something is amiss in the EVAP System; what is the best approach to take? By-pass the system? I cannot see any obvious loose or worn connection ; to be honest all the pipes look 19 years old; its hard to tell what is causing the issue. I looked at the MKIV article on how to bypass the Charcoal canister but it is pants , anybody have a decent How to Do? thanks Link to comment Share on other sites More sharing options...
Ian C Posted July 26, 2012 Share Posted July 26, 2012 It's ok, it's just very hard to help remotely without some detailed info Didn't realise it was stemming off that other problem, I'd missed your updates on that so hadn't gone back to it. Has it been making this noise since you had the power loss on the track? Link to comment Share on other sites More sharing options...
Jellybean Posted July 26, 2012 Author Share Posted July 26, 2012 (edited) Ian C said: It's ok, it's just very hard to help remotely without some detailed info Didn't realise it was stemming off that other problem, I'd missed your updates on that so hadn't gone back to it. Has it been making this noise since you had the power loss on the track? Its cool, really appreciate the Help Ian! No Just since I re-connected the Idle air reference hose but since I disconnected it she idles and sounds normal; she seems to boost as normal with the Idle air reference hose disconnected; I presume the Diaphram in the VSV is preventing any boost leak I know the Clutch plates can rattle on Idle; it is a bit annoying! Edited July 26, 2012 by Jellybean (see edit history) Link to comment Share on other sites More sharing options...
Ian C Posted July 26, 2012 Share Posted July 26, 2012 I'll have a re-read of your problem, that sounds quite bizarre. I've pinched this as an example for a sticky I just made Link to comment Share on other sites More sharing options...
Jellybean Posted July 26, 2012 Author Share Posted July 26, 2012 Ian C said: I'll have a re-read of your problem, that sounds quite bizarre. I've pinched this as an example for a sticky I just made Cool , Glad to be of help! I am in a pickle and I am at a loose end on what to do next; SSI (supra specialist Ireland) is 2.5 hours drive away so I am trying to do everything I can first to resolve the issue. What has me confused, is why she boosts ok with the Idle air reference hose disconnected; I would of taught this will create a boost leak? Diaphram in the VSV is preventing any boost leak? My other concern is, obviously this hose helps circulate the fuel vapours via the Charcoal canister ; with it disconnected I will get a build up of petrol vapours,Will this damage the Engine? or will I be heading down the motorway with ACDC on full WOT in a ball of fire! Link to comment Share on other sites More sharing options...
Ian C Posted July 26, 2012 Share Posted July 26, 2012 I've responded to your other thread. I need to be clear which hoses are connected to what and where they go before making any more assumptions I'm still not completely sure what you've got plumbed into where, so give me a roundup in that thread. Also, don't worry about the EVAP stuff just yet, the worst you'll get is a petrol smell. I haven't had a charcoal canister for years. Link to comment Share on other sites More sharing options...
Jellybean Posted July 26, 2012 Author Share Posted July 26, 2012 Ian C said: I've responded to your other thread. I need to be clear which hoses are connected to what and where they go before making any more assumptions I'm still not completely sure what you've got plumbed into where, so give me a roundup in that thread. Also, don't worry about the EVAP stuff just yet, the worst you'll get is a petrol smell. I haven't had a charcoal canister for years. Thanks Ian, I got pics too! Link to comment Share on other sites More sharing options...
