The-Plethora Posted July 24, 2012 Share Posted July 24, 2012 Right guys, I hope you can help and have my sanity and hands from being cut to ribbons. A few months back I damaged the passenger side alarm sensor that sits on the passenger pillar and have recently got a new one to install. Now this involves finding the after market control box and so removing dash panels. That bit I think I can handle, at the same time it made sense to have a de-clutter of all the junk cabling that was behind the dash. So far I have removed two sunvisor TV screen control boxes and an amplified ariel for the analogue TV tuner on the head unit. Now I want to remove the defi heads up display unit that has been unplugged since I purchased the car and tidy up the wiring elsewhere. As you can see it's a bit of a bombsite at the moment.... Is there any way of removing the ducting for the air vents without removing the whole dash? as the wiring seems to be hidden behind it. Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted July 24, 2012 Share Posted July 24, 2012 I removed mine, there was a plastic clip in either end, took those out and the whole section moves, you can slide it towards the gear lever then release one end. Mine was tight but a bit of force and it will move. Quote Link to comment Share on other sites More sharing options...
