weskereric Posted July 23, 2012 Share Posted July 23, 2012 I've some problems with a tiptronic box in a TT Supra. Revs are going up but the car is not going forward in any gear in auto and manual gear, it's like the "clutch" is slipping. Transmission fluid is ok so I'll try to totally flush the gearbox with the hope that it's just that. Could it be anything else except the fluid or changing the torque converter/gearbox ? I've heard about the gearbox speed sensor could failed and cause this problem... Thanks for your help guys Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted July 23, 2012 Share Posted July 23, 2012 Drop the gearbox sump, replace/clean the gearbox filter, change the fluid. Quote Link to comment Share on other sites More sharing options...
weskereric Posted July 23, 2012 Author Share Posted July 23, 2012 That's the first thing I was thinking to do, we'll see Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted July 23, 2012 Share Posted July 23, 2012 You will go from slipping to no drive at all very quickly if you dont do it soon Quote Link to comment Share on other sites More sharing options...
L18msy Posted July 24, 2012 Share Posted July 24, 2012 Had a automatic car in last week doing that and the gearbox fluid was low. I would drain the box and fill up with fresh stuff. Quote Link to comment Share on other sites More sharing options...
Kaan W Posted July 24, 2012 Share Posted July 24, 2012 You will go from slipping to no drive at all very quickly if you dont do it soon Wise words... Quote Link to comment Share on other sites More sharing options...
weskereric Posted July 26, 2012 Author Share Posted July 26, 2012 (edited) Bad news: Toyota toldme that gearbox is dead, "there are some metallic noises when moving the selector inside the gearbox". I'll double check that but it's a strong possibility. In the case, I need to change it, is the tiptronic gearbox the same as the auto box or the same as the aristo tiptronic? They are all called A340E but each part number is different. Edited July 26, 2012 by weskereric (see edit history) Quote Link to comment Share on other sites More sharing options...
Havard Posted July 26, 2012 Share Posted July 26, 2012 Bad news: Toyota toldme that gearbox is dead, "there are some metallic noises when moving the selector inside the gearbox". I'll double check that but it's a strong possibility. In the case, I need to change it, is the tiptronic gearbox the same as the auto box or the same as the aristo tiptronic? They are all called A340E but each part number is different. Not good. How many miles has the car done and what power are you pushing? Quote Link to comment Share on other sites More sharing options...
weskereric Posted July 26, 2012 Author Share Posted July 26, 2012 It's nearly stock, with both cat and just 60k miles, previous owner had run without oil, if not I don't how it's possible... Quote Link to comment Share on other sites More sharing options...
Havard Posted July 26, 2012 Share Posted July 26, 2012 It's nearly stock, with both cat and just 60k miles, previous owner had run without oil, if not I don't how it's possible... Similar mileage and set up to mine then. Worrying..!! Quote Link to comment Share on other sites More sharing options...
dan294 Posted July 26, 2012 Share Posted July 26, 2012 Similar mileage and set up to mine then. Worrying..!! I've hopefully got Martin doing a gearbox oil and filter change on mine in the next few weeks! Keep hearing these stories of auto boxes failing. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted July 26, 2012 Share Posted July 26, 2012 60k indicated miles, as I always say never trust mileages unless backed up with a history. Not saying Toyota are wrong but I'd certainly get a second opinion Quote Link to comment Share on other sites More sharing options...
andz222 Posted July 26, 2012 Share Posted July 26, 2012 fully flush the torque converter Quote Link to comment Share on other sites More sharing options...
Havard Posted July 26, 2012 Share Posted July 26, 2012 I've hopefully got Martin doing a gearbox oil and filter change on mine in the next few weeks! Keep hearing these stories of auto boxes failing. Martin did ours just before Dragonball. We have never had a hint of trouble but I am going to check the fluid when I next go out in it. H. Quote Link to comment Share on other sites More sharing options...
Kirk Posted July 26, 2012 Share Posted July 26, 2012 No I did oil and filter on yours not the gearbox filter and fluid Quote Link to comment Share on other sites More sharing options...
Havard Posted July 26, 2012 Share Posted July 26, 2012 No I did oil and filter on yours not the gearbox filter and fluid Did you check the fluid though? Quote Link to comment Share on other sites More sharing options...
Kirk Posted July 26, 2012 Share Posted July 26, 2012 Of course. It was fairly clean from what I remember. Quote Link to comment Share on other sites More sharing options...
Havard Posted July 26, 2012 Share Posted July 26, 2012 Of course. It was fairly clean from what I remember. I thought so. We just did the things that needed doing at the time. May be brakes, gearbox and diff next? H. Quote Link to comment Share on other sites More sharing options...
Kirk Posted July 26, 2012 Share Posted July 26, 2012 Indeed it needed a service at the time, nothing more. If that's what you want to do just give us a shout Quote Link to comment Share on other sites More sharing options...
Havard Posted July 26, 2012 Share Posted July 26, 2012 Indeed it needed a service at the time, nothing more. If that's what you want to do just give us a shout I need to keep my favourite mechanic busy. I can't get hold of him so do you fancy doing it? Quote Link to comment Share on other sites More sharing options...
Kirk Posted July 26, 2012 Share Posted July 26, 2012 Quote Link to comment Share on other sites More sharing options...
dan294 Posted July 26, 2012 Share Posted July 26, 2012 Speaking of which Martin, did you speak to your mate about the small few jobs on mine? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 27, 2012 Share Posted July 27, 2012 If the box has shrapnel in it you MUST renew the torque converter, the only way to get shrapnel out of them is to lathe them open, clean them out whilst dismantled, weld them back up and have them rebalanced on a special balancer. The cooler and lines needs removing from the car and flushing or changing for ones off a car that's not had any dramas. Once an auto box slips for more than a few seconds it's usually DEAD! Quote Link to comment Share on other sites More sharing options...
