Jonnybravo2667 Posted July 22, 2012 Share Posted July 22, 2012 Hi everyone i have a problem with my o/s/r wheel rattling, symptoms are a rattle when that wheel hits a pothole and also i tested the wheel for play on the bearing. There no play if i hold the wheel at either side but there movement if i hold it at top and bottom, any ideas? Thanks for any replies Quote Link to comment Share on other sites More sharing options...
Nic Posted July 22, 2012 Share Posted July 22, 2012 Get the car on a ramp, torque up all the bolts to manufacturers spec and check all the bushes, joints and bearings for wear. http://www.turbosupras.com/pdfs/JZA80%20TSRM/SA.pdf Quote Link to comment Share on other sites More sharing options...
straightsix Posted July 22, 2012 Share Posted July 22, 2012 Possibly drop links but have you checked the tailgate rubbers for wear as my old Supra had a rattle that sounded like it was coming from the suspension but turned out to be these on one side. Quote Link to comment Share on other sites More sharing options...
sideexitsupra Posted July 22, 2012 Share Posted July 22, 2012 I recently had a bearing go. It was completely f'ed but there was no play. Quote Link to comment Share on other sites More sharing options...
Guest samc82 Posted September 30, 2012 Share Posted September 30, 2012 I had the exact same probs mate turned out to be the inside bushes on the upper suspension arm were shagged ended up getting urethane bushes pressed in as a new wishbone was a ridiculous price Quote Link to comment Share on other sites More sharing options...
Dnk Posted September 30, 2012 Share Posted September 30, 2012 If you have movement on the wheel holding it top to bottom then there's a good chance you have wear in the upper or lower arm bushes or ball joints. This might not be your noise though so as suggested get it on a ramp asap and do as Nic suggests first. Quote Link to comment Share on other sites More sharing options...
