Brian Jackett Posted February 28, 2003 Share Posted February 28, 2003 Is it the order of furthest away from master cylinder i.e. n/s rear first Tried to search but could not get any results regards Link to comment Share on other sites More sharing options...
Adam W Posted February 28, 2003 Share Posted February 28, 2003 Yep, bleed the longest lines first, n/s/r; o/s/r; n/s/r; o/s/r Link to comment Share on other sites More sharing options...
Brian Jackett Posted February 28, 2003 Author Share Posted February 28, 2003 Thanks, just out of interest I always bleed without engine on and NOT using the servo boost. Can this help bleed or is this a no no Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 28, 2003 Share Posted February 28, 2003 Originally posted by Adam Wootten Yep, bleed the longest lines first, n/s/r; o/s/r; n/s/r; o/s/r No wonder you have brake trouble, try bleeding the FRONTS some time... Link to comment Share on other sites More sharing options...
Ian C Posted February 28, 2003 Share Posted February 28, 2003 Arf arf, shame someone noticed that before me Link to comment Share on other sites More sharing options...
Need4Speed Posted March 2, 2003 Share Posted March 2, 2003 Thanks, just out of interest I always bleed without engine on and NOT using the servo boost. I was informed that with ABS, do it with the engine running. I did and at worked fine, but I've not tried it without and haven't decided if there's any logic in it. Disconnecting the servo is not necessary. Link to comment Share on other sites More sharing options...
B3any Posted March 3, 2003 Share Posted March 3, 2003 Does it really matter which ones you bleed 1st as long as there done properly, just done mine and did one side 1st then the other side its fine.... Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 3, 2003 Share Posted March 3, 2003 Originally posted by B3any Does it really matter which ones you bleed 1st as long as there done properly, just done mine and did one side 1st then the other side its fine.... Not REALLY. It is sometimes necessary to bleed in a certain order, and on UK cars with the ABS pump specially doctored to run all the time, if the fluid has been drained completely, or if because of the old "Sods Law" it is a PITA to get air out of. I wouldn't worry if you have a good firm pedal. Link to comment Share on other sites More sharing options...
B3any Posted March 3, 2003 Share Posted March 3, 2003 We never let it dry out, seems good, pedals not as firm as i'd like but i got stainless hoses too fit yet..... Link to comment Share on other sites More sharing options...
