barneybrendan Posted July 20, 2012 Share Posted July 20, 2012 how do you remove the tt auto gearbox without having to take the engine out.My stress levels are through the roof. Quote Link to comment Share on other sites More sharing options...
dan294 Posted July 20, 2012 Share Posted July 20, 2012 PM Kaan W mate, he took his off not so long back. Quote Link to comment Share on other sites More sharing options...
Kaan W Posted July 20, 2012 Share Posted July 20, 2012 What are you stuck on matey? Quote Link to comment Share on other sites More sharing options...
baldy Posted July 20, 2012 Share Posted July 20, 2012 yes no need to removed engine,its best to removed to torque converter bolts from the drive plate n leave the converter in place Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted July 20, 2012 Author Share Posted July 20, 2012 What are you stuck on matey? cheers all off now. Quote Link to comment Share on other sites More sharing options...
Kaan W Posted July 20, 2012 Share Posted July 20, 2012 cheers all off now. No worries Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 20, 2012 Share Posted July 20, 2012 You MUST MUST MUST always leave the TC on the gearbox, if you try to leave it bolted to the flex plate and pull the box off the TC you will at the very least knacker the pump seal in the box, and quite probably knacker the pump as well. You can even knacker the TC itself, and bend the flex plate. This applies to 99% of automatic cars. Once the flex plate to TC bolts are out gently push the TC right into the gearbox itself, as far as it will go with your fingers. Don't let if fall out as you manoeuvre the gearbox out!! Quote Link to comment Share on other sites More sharing options...
Caesard Posted July 20, 2012 Share Posted July 20, 2012 The sage has spoken. All hail King Chris Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted July 21, 2012 Share Posted July 21, 2012 The sage has spoken. All hail King Chris i need a pic of chris so i can have shrine cast in bronz for the workshop. ive allways said, when i grow upi want to be him Quote Link to comment Share on other sites More sharing options...
Abz Posted July 21, 2012 Share Posted July 21, 2012 i need a pic of chris so i can have shrine cast in bronz for the workshop. ive allways said, when i grow upi want to be him Isn't this the current one you have of Chris? http://www.recyclesantafe.org/pic/artshow_3.jpg Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted July 21, 2012 Share Posted July 21, 2012 Isn't this the current one you have of Chris? http://www.recyclesantafe.org/pic/artshow_3.jpg have you been in my pants draw again? Quote Link to comment Share on other sites More sharing options...
mclarenross Posted August 14, 2012 Share Posted August 14, 2012 Hi guys, Sadly when I got my 1jzgte gearbox sent to me the the tc had already been taken out... We tried getting the gearbox on tonight by sliding the engine (with tc attached) on to the gearbox, but just could get it to marry up and fit... Rising stress levels we ended up just fitting the engine on it's mounts and dropping the gearbox out underneath, later this week we were going to put the tc on te gearbox end and try it that way... Is that the best way? Only issue I can see with that is that when offering up the gearbox to the engine it might not fit with the gearbox attached to the prop shaft... Any help would be appreciated !! Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 14, 2012 Share Posted August 14, 2012 Did you not read my post regarding NEVER removing / fitting an engine or gearbox with the TC attached to the engine? You will almost certainly have knackered the gearbox oil pump seal, and MAY have damaged the oil pump itself, in the nose of the gearbox. The TC neck has two cut outs that drive dogs inside the oil pump. The reason the engine / box wouldn't mate up properly is these dogs were not aligned. You align them by VERY carefully fully supporting the TC and sliding and tuning it into the gearbox bellhousing, feeling for the slots / dogs to align and the TC to go fully home into the g/box. If you used much force at all to mate the two up when the slots / dogs were misaligned you may have broken the gearbox oil pump!!! BIG expense. you may have damaged the neck of the TC! You need to strip the pump out of the auto box and check it out. I'd let an auto box specialist do that. Quote Link to comment Share on other sites More sharing options...
mclarenross Posted August 14, 2012 Share Posted August 14, 2012 The words bugger and f**k spring to mind lol! Quote Link to comment Share on other sites More sharing options...
