R154 sensors?
-Welsh-Stealth-
i believe this is the right place to put this as it's going on my supra. any problems i appologise.
I'm due to fit my R154 conversion to my NA-T soon as some will know.& im keeping it as a road legal car. so i will need to fit the speed sensor and reverse sensor. does anybody know which ones i will need & where i can get them from?
thanks in advance guys ;)
Cheers guys! Perfect!
Will see how difficult it is to swap the speed sensors over, but ideally will go for a new one. Don't want to be stripping a box just to get at a single nut. At least the MOT isn't due for a couple of months!
& with the reverse sensor it take it's just a live& an earth that will need soldering & heat wrapping on? Only reason I ask is haven't had a look at the box yet.
I paid 20 quid for my W58 sensor. You don't have to strip the box, just change the cog on the speed sensor for the one on the cable driven one that came out of the hole.
As for wiring, you need to find a +12v feed, shove that to one side of the switch, and then find the wire that feeds the block connector under the dash as the "reverse switch", and join it to that. Essentially, > In Reverse = 12V to that wire.
- - - Updated - - -
Have you got the shifter extended yet?
- - - Updated - - -
nice easy one for one swap on the speed sensor then huh.
as for the revese wiring cant you use the stadard loom from the w58 to wire in the r154 reverse sensor?
& just to confirm the speed sensor is the one closer to the bell housing on the w58& the reverse prop end? is that the same for the R154?
and as for the R154....iv managed to order the parts required to modify the back of the box to convert it to the soarer style shifter ;)
