merckx Posted July 19, 2012 Share Posted July 19, 2012 I've had little bits of rust in the wheel arches (around the suspension) and underneath, so I've decided to do it properly and remove everything back to bare metal. I'm using 3 coats of Por 15 paint but I'm not sure what to use as a final layer underneath the car, I'll be using stonechip in the wheel arches and was thinking should I use this underneath aswell or use an underseal. So, I planned to use Upol Gravitex Stonechip or should I use Dinitrol stonechip, it's more expensive. Should I use stone chip underneath or an underseal (underbody wax) such as Dinitrol, will this give provide better sound deadening? Thanks Link to comment Share on other sites More sharing options...
SteveR Posted July 19, 2012 Share Posted July 19, 2012 I'm interested in the answers you get to this - subscribed. Link to comment Share on other sites More sharing options...
Jellybean Posted July 19, 2012 Share Posted July 19, 2012 use schultz underseal, takes about 24 hours for it to Cure after application, once cured it is like a rubber sealant Dont use any stone chip to underseal as it is prone to cracking You can also use Billet hammer cavity wax to do inside the sills from the inside, lift back the carpet to get access Use Zinc on Metal componets (suspenion arms); you are galvanising the metal components with the Zinc Spray (Bilt-Hamber Electrox; 3M™ Zinc Spray 16-501) Photos of it cured ; it will get soon look OEM after a few weeks of driving from what I am told(Loose the shine) Link to comment Share on other sites More sharing options...
merckx Posted July 19, 2012 Author Share Posted July 19, 2012 Thanks Jellybean Yes, I was looking at the Dinitrol Shultz underseal and I was surprised that it comes out of the gun with a gloss finish. The UPol Gravitex stonechip (black) is a nice matt very dark grey finish which I may put on top. Link to comment Share on other sites More sharing options...
Jellybean Posted July 19, 2012 Share Posted July 19, 2012 Thanks Jellybean Yes, I was looking at the Dinitrol Shultz underseal and I was surprised that it comes out of the gun with a gloss finish. The UPol Gravitex stonechip (black) is a nice matt very dark grey finish which I may put on top. From what I was told, over time it will eventually loose the shine and go dark grey Link to comment Share on other sites More sharing options...
merckx Posted July 19, 2012 Author Share Posted July 19, 2012 From what I was told, over time it will eventually loose the shine and go dark grey Thanks, I'll just go for the underseal then. Link to comment Share on other sites More sharing options...
Jellybean Posted July 19, 2012 Share Posted July 19, 2012 Thanks, I'll just go for the underseal then. Oh yeah The pics above is after 40 miles from when it was done Link to comment Share on other sites More sharing options...
