cooke Posted July 16, 2012 Share Posted July 16, 2012 Has anyone put these into an na, are the compatable and work with no problems Quote Link to comment Share on other sites More sharing options...
Nic Posted July 17, 2012 Share Posted July 17, 2012 NGK BKR5EIX-11, have a read of this thread http://www.mkivsupra.net/vbb/showthread.php?41927-FAQ-Spark-plugs&highlight=plugs Quote Link to comment Share on other sites More sharing options...
BK1 Posted July 17, 2012 Share Posted July 17, 2012 NGK BKR5EIX-11, have a read of this thread http://www.mkivsupra.net/vbb/showthread.php?41927-FAQ-Spark-plugs&highlight=plugs Recommendations are great but it doesn't really answer his question Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted July 17, 2012 Share Posted July 17, 2012 To answer your question, you can put whatever type of plug you like in, providing its the correct heat grade, thread and reach, if your looking at iridium plugs as some kind of upgrade, then you won't see any difference in performance increase from fitting different plugs. The only difference between precious metal plugs IE iridium, platinum from copper cored type is that they are intended for extended service life, nothing else. Quote Link to comment Share on other sites More sharing options...
LOGIE Posted July 17, 2012 Share Posted July 17, 2012 I fitted them about a year or so ago, I say deffinately fit them as they are long life and changing the plugs on an NA is a big pain due to having to remove the throttle body. They will last for approx 60,000 mile so you wont need to go near them again for a while. Also i did get a better throttle response and slightly better MPG return.. but my old copper plugs were looking worn out when removed. So "Yes" they are worth it very much so IMO Quote Link to comment Share on other sites More sharing options...
cooke Posted July 17, 2012 Author Share Posted July 17, 2012 Thanks very much for the info Quote Link to comment Share on other sites More sharing options...
BK1 Posted July 17, 2012 Share Posted July 17, 2012 I fitted them about a year or so ago, I say deffinately fit them as they are long life and changing the plugs on an NA is a big pain due to having to remove the throttle body. They will last for approx 60,000 mile so you wont need to go near them again for a while. Also i did get a better throttle response and slightly better MPG return.. but my old copper plugs were looking worn out when removed. So "Yes" they are worth it very much so IMO Nice one mate, that's the answer we wanted! I've been putting off doing mine because of the throttle body, but getting the iridium ones means it'll be a job that I'll probably only eveer do once Quote Link to comment Share on other sites More sharing options...
David P Posted July 17, 2012 Share Posted July 17, 2012 I have a set of these, ran them for a week then swapped for Halo's, pm me a sensible offer and they're yours. Quote Link to comment Share on other sites More sharing options...
Nic Posted July 17, 2012 Share Posted July 17, 2012 Recommendations are great but it doesn't really answer his question Nice one mate, that's the answer we wanted! If you'd have read the FAQ link I'd posted you'd have all the answers you needed. Quote Link to comment Share on other sites More sharing options...
BK1 Posted July 17, 2012 Share Posted July 17, 2012 Yeah did that. Like I said already, recommendations aren't the same as practical experience. Quote Link to comment Share on other sites More sharing options...
Nic Posted July 18, 2012 Share Posted July 18, 2012 (edited) Yeah did that. Like I said already, recommendations aren't the same as practical experience. All the threads in FAQ section were written by very experienced members with over a decade of practical experience, they can be trusted to be accurate. Edited July 18, 2012 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
Guigsy Posted July 18, 2012 Share Posted July 18, 2012 Surely people wouldn't recommend them if they didn't work or were crap... Quote Link to comment Share on other sites More sharing options...
BK1 Posted July 18, 2012 Share Posted July 18, 2012 All the threads in FAQ section were written by very experienced members with over a decade of practical experience, they can be trusted to be accurate. Calm down my friend, I'm not questioning anyone's knowledge or experience. I'm in awe of the breadth and depth of knowledge and experience amongst our members. I've made good use of it on many occasions. All I meant was that when there are choices available, it's just nice to know that someone has actually used those plugs and not found any issues Quote Link to comment Share on other sites More sharing options...
