New wheels!
Marcus GTE
Thought i'd post up some pics of the new wheels now they have been fitted for those of you that havent seen them.
They are Wedssport SA-70 18" bronze wheels with a +32 offset in a staggered 9J and 10J.
Nuts are temporary.
Special thanks to Nic for his help with wheels advice. :thumbs:
Edited by Marcus GTE (see edit history)
Cheers guys, i agree they change the car. looks more aggressive :)
I will prob lower it a bit at some point, its on D2 coilovers so they are pretty adjustable. Arch rolling/ shaving will most likely be needed though. For the moment i'll just enjoy no longer scraping my drive every time i come home :D
Amazing how a nice set of wheels will make such a drastic improvement in the looks department. It's perfect now ! Absolutely stunning.
May i ask what tire size are you running on the rear i will have a similar setup (10.5J, ET40) and would want to know if stock arches are ok.
Thanks
Edited by alex2jz (see edit history)
At the moment they are 235 fronts and 265 rears if it heps you, although they are smaller than the ones you are talking about (10.5j and mine are 10 on the rear)
Thanks
Thanks for the answer mate. Yes, mine will be 10.5J indeed but with a +40 offset. This means they will actually sit 2mm further in. But i'm going to use a 275 tyre so it will be pretty much identical :)
