tina n paul Posted July 15, 2012 Share Posted July 15, 2012 as above guys i bought this car yesterday and i noticed the smaller instrument cluster to right side of dash isnt lighting up ,, shouldnt there be some lights in there ? im refering to the information cluster top right of speedo . small slim panel oblong shape left side one lights up cat overheat light etc and goes out but nothing lighting up on right side its an na auto aerotop 1993 , cheers paul Quote Link to comment Share on other sites More sharing options...
Josh42 Posted July 15, 2012 Share Posted July 15, 2012 The display units are common for suffering dry solder, try removing the panel and moving the connector up and down with the keys in the ignition, see of you can get them to light up. Mine didn't work until I wedged something under the connector block:) Quote Link to comment Share on other sites More sharing options...
Josh42 Posted July 15, 2012 Share Posted July 15, 2012 And welcome to the aerotop club by the way:) Quote Link to comment Share on other sites More sharing options...
L18msy Posted July 15, 2012 Share Posted July 15, 2012 The display units are common for suffering dry solder, try removing the panel and moving the connector up and down with the keys in the ignition, see of you can get them to light up. Mine didn't work until I wedged something under the connector block:) Yeah that. Drop a fresh bit of solder into the connections. Quote Link to comment Share on other sites More sharing options...
tina n paul Posted July 15, 2012 Author Share Posted July 15, 2012 Cheers guys , will do that thanks for the tip . Quote Link to comment Share on other sites More sharing options...
DJT88 Posted July 18, 2012 Share Posted July 18, 2012 You could try gently tapping the dash, I've had mine out 3 times, and after putting it back in, it also didn't light up completely. An encouraging tap next to the cluster did the trick. Quote Link to comment Share on other sites More sharing options...
