Does anyone run 275 40 18 rear tyres?
SamuraiFlash
My tyres will need changing on the rears very soon, I currently run 275 35 18's and I'd like to go to a set of 275 40's for the higher sidewall. If I was to change there will be a rolling radius change of +4.15%, in what way will this affect my car apart from the speedo and have you guys had any issues?
I just like the look of a fat sidewall and the comfort will be a bonus, any pics would be appreciated.
Thank you :D
The rear lips have been trimmed to the centre of spot-welds at the top so there was no problem, but it would be touch and go without.
It will be dependant on your wheel size and offset, these are 10J ET 45.
This might help.
http://www.1010tires.com/WheelOffsetCalculator.asp
The fronts are 8.5J ET 40 with 245 40 18.
All this info is in my garage, you just need to pluck up the courage to press a button and look.
Edited by David P (see edit history)
Depends what you're comparing against, of course. If it was originally a J-spec TT you could be almost 10% out.
225/50-16 0.00%
275/40-18 7.3%
285/40-18 8.5%
245/45-16 0.00%
275/40-18 8.0%
285/40-18 9.3%
255/40-17 0.00%
275/40-18 6.5%
285/40-18 7.8%
Speedometers invariably over-read on the stock size.
