skyludeboy Posted July 13, 2012 Share Posted July 13, 2012 I kind of figured that part of the reason my front crank seal went was due to my current breather system setup, any one got any tips or diagrams to how a good breather system should look like, I have removed both pcv valves on intake and exhaust side and welded -10 fitting to both cam covers, exhaust side is vented to atmosphere, intake side is going to catch tank which is vented to atmosphere, is what I have done wrong? help appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
JamieP Posted July 13, 2012 Share Posted July 13, 2012 Nothing wrong with that, both sides of mine just vent under the car, never had an issue. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted July 13, 2012 Share Posted July 13, 2012 The stock set up is perfectly fine, but theres many different ways to skin a cat. Jamie's exit under the car, my exhaust side is piped to my intake pipe and intake side is stock. The seal went because seals wear out, pretty simple really. Quote Link to comment Share on other sites More sharing options...
Guigsy Posted July 13, 2012 Share Posted July 13, 2012 both of mine go to the intake. there is a good thread about it but i dont think there is a preffered best way. but there are some "dont do's" Quote Link to comment Share on other sites More sharing options...
johnny g Posted July 13, 2012 Share Posted July 13, 2012 both of mine go to the intake. there is a good thread about it but i dont think there is a preffered best way. but there are some "dont do's" I think jevansio did some tests on vacuum. I'll see if I can dig out the link. Quote Link to comment Share on other sites More sharing options...
hodge Posted July 13, 2012 Share Posted July 13, 2012 I'm the same as Jamie, mine just vent under the car. I've never had issues either. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted July 13, 2012 Share Posted July 13, 2012 I also did some pretty comprehensive tests on the stock breather system, in an effort to eliminate this a a possible cause for FMS failure, and the result is that 98% of the time FMS failure is down to worn oil pump or badly fitted seal, do some searching and you will find lots relating to this subject. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted July 14, 2012 Share Posted July 14, 2012 I think jevansio did some tests on vacuum. I'll see if I can dig out the link. That was a quality thread Quote Link to comment Share on other sites More sharing options...
little num Posted July 14, 2012 Share Posted July 14, 2012 Since having my engine out i have tapped the block both sides where the unused engine mount holes are and fitted -10 in there that go to my catch cans either side of the engine bay, i also have tapped the rockers and again used -10 that also go to the catch cans so have 4 breathers in total 2 from the block and 2 from the rockers. Ive thought about venting the block breather back into the cams then cam breather to catch can so it gives the bottom and top an equal pressure but cant be bothered at the minute, would rather drive the thing instead of keep spending and fixing it. I can take some pics if you like tomorrow. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted July 15, 2012 Share Posted July 15, 2012 Can i ask why you have gone to so much trouble doing all that, have you had server ring seal problems? the 2JZ PCV system works well, and there are no problems with crankcase presurisation running quite high boost and power figures. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted July 15, 2012 Share Posted July 15, 2012 mine vent to atmosphere and exit at the back of the car.no seal issues here Quote Link to comment Share on other sites More sharing options...
mellonman Posted July 15, 2012 Share Posted July 15, 2012 i just kept mine as stock but through a catch can before the intake on the turbo side,and kept intake side completely stock. Quote Link to comment Share on other sites More sharing options...
