clutch advice
andyi
Might be a good idea to get in contact with cris willson! He is a trader on here and I'm sure he does an updated OEM clutch for the TT6 that is ment to be good. You can put a solid flywheel on but you get some transmission noise from it. I'm sure you will be able to get away with the stock flywheel at BPU levels.
Keep the stock flywheel, speak to Chris Wilson about an uprated friction plate and clutch cover, that should give you a clutch that can take the increase in power with the ease of use of the stock clutch. Always spec the clutch to the power you are running, the worst thing you can do to the driving experience is to fit a so called 'performance' aftermarket clutch/flywheel, as most tend to be heavy to operate, noisy and grabby.
