Supraman Posted July 13, 2012 Share Posted July 13, 2012 Hi guys, basically the supra has been burning alot of oil, and smokes really badly on boost (Black smoke). The mechanic told me about additives which can sometimes cure the above problem, was just wondering if anyone had any experience with these? Also which oil do you guys all use ? cheers, Ryan Link to comment Share on other sites More sharing options...
Ian C Posted July 13, 2012 Share Posted July 13, 2012 Additives won't ever fix missing metal The only way it'd help is by thickening the oil up so much that it doesn't fit out of the gaps so much any more, and the knock-on effect of that in small galleries and the oil pump isn't worth contemplating. It is also more likely that it's the turbo seals, possibly because the turbo is unbalanced due to vane damage. As for the oil question, there is an oil faq lurking in the tech section Link to comment Share on other sites More sharing options...
Supraman Posted July 13, 2012 Author Share Posted July 13, 2012 Thanks for that, so its possibly rebuild time? In regards to the turbo seals the guy was saying he had the inlet manifold off and there was nothing in there so he though it wasnt the turbo seals, does that sound about right ? I also though originally turbos seals, there is oil coming out of the dump valve... Ryan Link to comment Share on other sites More sharing options...
Supraman Posted July 13, 2012 Author Share Posted July 13, 2012 Bump Link to comment Share on other sites More sharing options...
Geo Posted July 13, 2012 Share Posted July 13, 2012 Ryan 10w50 Valvoline(used to be silkolene) can you explain more details about your problem? does it only happen on boost? etc does it go away after driving? what garage did you use? Link to comment Share on other sites More sharing options...
Alex Posted July 13, 2012 Share Posted July 13, 2012 (edited) Oil coming out of the BOV can be normal but also can show elevated oil levels in the breather system and therefore it is a problem in the block. I think you'll have to take the head off to be sure. Research points for the symptoms I can think of are; Valve Stem Oil Seals Oil Viscosity - your oil vs recommended. Piston Ring Failure Turbo failure...this won't necessarily show in the intake side of the turbo. Never add an additive to oil you don't know what the side effects will be. Edited July 13, 2012 by Alex (see edit history) Link to comment Share on other sites More sharing options...
Alex Posted July 13, 2012 Share Posted July 13, 2012 Silkolene is now Fuchs, not Valvoline...the Fuchs Titan Pro Race S 10w50 is the best I know of. Ryan 10w50 Valvoline(used to be silkolene) can you explain more details about your problem? does it only happen on boost? etc does it go away after driving? what garage did you use? Link to comment Share on other sites More sharing options...
Geo Posted July 13, 2012 Share Posted July 13, 2012 Silkolene is now Fuchs, not Valvoline...the Fuchs Titan Pro Race S 10w50 is the best I know of. my mistake, Fuchs is the stuff you want Link to comment Share on other sites More sharing options...
hodge Posted July 14, 2012 Share Posted July 14, 2012 Is the issue as the car IS on boost or when you lift off the throttle? Also, you original post said black smoke, oil makes blue smoke, black is a fueling issue. Link to comment Share on other sites More sharing options...
Supraman Posted July 14, 2012 Author Share Posted July 14, 2012 On boost its very Smokey. Will get one of the guys to confirm colour tomorrow. Wasnt a specialist garage just a little one in coatbridge who checked it but checkpoint in.Arbroath rebuilt the car less than 3000 miles ago so it will be going back there I think. Sorry for the brief reply I'm in work just now. Will update with more info tomorrow after the Scottish car show. Thanks for all the help so far guys. Link to comment Share on other sites More sharing options...
Supraman Posted July 14, 2012 Author Share Posted July 14, 2012 It was also at whifbitz not long ago but I wasn't with the car. My dad said Paul noticed the engine was pretty noisy and the valve stem oil seals could be away. Cheers, Ryan Link to comment Share on other sites More sharing options...
dandan Posted July 14, 2012 Share Posted July 14, 2012 Check the little PCV valve on the intake side cam cover. If it's buggered it can cause excessive smoking on boost. What oil is in there anyway? Link to comment Share on other sites More sharing options...
Swampy442 Posted July 14, 2012 Share Posted July 14, 2012 Thought black smoke was unburnt fuel? Link to comment Share on other sites More sharing options...
