Sted Posted July 13, 2012 Share Posted July 13, 2012 Does any one know which pin to brake into on the vvti ecu? I have printed off the diagrams that are on here but I can't find out which pin to use on a vvti. Ste. Quote Link to comment Share on other sites More sharing options...
rob wild Posted July 13, 2012 Share Posted July 13, 2012 (edited) I think its block B pin 15 on a VVti ECU (this is on Ian C's diagram) On this diagram its B75 pin 9 black and yellow wire:- http://www.2jzgarage.com/wp-content/uploads/2012/01/Supra_2JZGTE_VVTi_ECU_Pinouts.pdf Edited July 13, 2012 by rob wild (see edit history) Quote Link to comment Share on other sites More sharing options...
Sted Posted July 13, 2012 Author Share Posted July 13, 2012 I think its block B pin 15 on a VVti ECU (this is on Ian C's diagram) On this diagram its B75 pin 9 black and yellow wire:- http://www.2jzgarage.com/wp-content/uploads/2012/01/Supra_2JZGTE_VVTi_ECU_Pinouts.pdf Thanks Rob for all your help this afternoon fitting my fuel cut. Quote Link to comment Share on other sites More sharing options...
rob wild Posted July 13, 2012 Share Posted July 13, 2012 No problem fella a pleasure enjoy the boost Quote Link to comment Share on other sites More sharing options...
Havard Posted July 13, 2012 Share Posted July 13, 2012 No problem fella a pleasure enjoy the boost Mine next? Quote Link to comment Share on other sites More sharing options...
rob wild Posted July 13, 2012 Share Posted July 13, 2012 Mine next? Yep well you need to order the bits, cooler spark plugs, Walbro pump, double de-cat and an FCD then we can sort it! Although can you handle the extra boooossstttt Ste's pulled really well today Quote Link to comment Share on other sites More sharing options...
Kirk Posted July 14, 2012 Share Posted July 14, 2012 Ill give a week till it explodes if Robs touched it Quote Link to comment Share on other sites More sharing options...
rob wild Posted July 14, 2012 Share Posted July 14, 2012 Ill give a week till it explodes if Robs touched it Non of the work I ever did on my own car or other peoples cars ever went wrong Quote Link to comment Share on other sites More sharing options...
Kirk Posted July 14, 2012 Share Posted July 14, 2012 Rob your jinxed unfortunately Quote Link to comment Share on other sites More sharing options...
Sted Posted July 14, 2012 Author Share Posted July 14, 2012 (edited) Non of the work I ever did on my own car or other peoples cars ever went wrong Just been out on a dry road unlike yesterday and its still pulling really well :D I have got lots of confidence in your work Rob if anyone else is fitting a FCD on the Vvti it is B75 pin 9 black and yellow wire:- that you need to brake into. Ste. Edited July 14, 2012 by Sted (see edit history) Quote Link to comment Share on other sites More sharing options...
214supra Posted August 29, 2012 Share Posted August 29, 2012 Just been out on a dry road unlike yesterday and its still pulling really well :D I have got lots of confidence in your work Rob if anyone else is fitting a FCD on the Vvti it is B75 pin 9 black and yellow wire:- that you need to brake into. Ste. Thinking of fitting mine soon, 98 vvti manual. will it still be the same if is an manual ( B75 pin 9 )? phill Quote Link to comment Share on other sites More sharing options...
