dr_jekyll Posted July 12, 2012 Share Posted July 12, 2012 bit confused with rings again. i thaught the 2jzge and 2jzgte ring were different but all the sets im looking at say they the correct aplication for both? can anybody confirm they are the same ? Quote Link to comment Share on other sites More sharing options...
SilentAgro Posted July 12, 2012 Share Posted July 12, 2012 I thought they should be. The only difference in the pistons is the top? The TT is concave for lower compression? As you can see with the ? I'm not to sure. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted July 12, 2012 Author Share Posted July 12, 2012 the pistons are the same 86.mm bore , im just unsure about the grooves for the ring in the piston being the same . it looks the same but the tiny differences are not allways visual. i may be wrong but i just had an incling the oem ring sets have different part numbers Quote Link to comment Share on other sites More sharing options...
Nic Posted July 12, 2012 Share Posted July 12, 2012 Checked the EPC the piston ring sets have different part numbers for the GE and GTE. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted July 12, 2012 Author Share Posted July 12, 2012 thanks nic, thats what i thaught Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted July 12, 2012 Author Share Posted July 12, 2012 so im reading more on spec and im not finding a difference , can anybody point out what im missing Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted July 12, 2012 Author Share Posted July 12, 2012 also would there be any advantage to going for 86.2 seeing as the bores have bben re honed or will they just not fit and ruin everything? Quote Link to comment Share on other sites More sharing options...
little num Posted July 12, 2012 Share Posted July 12, 2012 rehoned bores are totally within the toyota tolerance and takes vitually nothing out, boring the bores then you would need to change not only rings but pistons also. You only order standard size rings unless there has been a major problem with the bores. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted July 12, 2012 Author Share Posted July 12, 2012 cheers mate 86 it is. noe i just need to find the differences in the ge and gte rings Quote Link to comment Share on other sites More sharing options...
