Oil For TRD Diff
dandan
What oil are people running in their TRD diffs?
I've seen people mention Motul Gear 300 LS 75-90, Motul Gear 75-140, Red Line GL5 75-90, and Royal Purple offerings as well.
I'm leaning towards the MG 300 LS 75-90.
Cheers
Dan
OK thanks Lee - I'm glad I asked :) I'll go for the Millers as you recommend.
Out of interest, what do you use/recommend for engine oil in any stock block single cars like mine? I'm running Silkolene/Fuchs Pro S 10w50.
Good thread, Dan. I've been using the Castrol 75-140, but mostly because I've got a leak at the seals, so will try Lee's suggestion on Monday when he sorts it out.
I've got a few measurements to check on mine (backlash and preload) and then I'll get mine fitted - probably next weekend. I've do have some questions about the install but will start a different thread.
  • 6 months later...
