what sort of rivets for body work
ashbuster
yeah mate im more talking about the style
the ones i need im sure they are like these
http://www.steam4fun.com/50-X-GENUINE-MAMOD-LARGE-ALLOY-RIVETS
because the solid rivets have to be hit from behind dont they? which would be impossible
http://www.gasgoo.com/showroom/marketspareparts/auto-products/1316593.html
Edited by ashbuster (see edit history)
The aviation industry use cherry rivets mainly these days which I have to say are pretty good rivets. Avdels are good but you have to mill them down. Solids are the best bet but like you said you need to get to the back of them to react them and you need a sensible gun (not a frickin air hammer) to blat em down properly. Also solids don't work well/at all with composites and plastics.
http://www.ebay.co.uk/itm/SURPLUS-AIRCRAFT-RIVETS-JOB-LOT-CHERRYS-SOLIDS-TAP-KS-ETC-/130727089695?pt=UK_CPV_Aviation_SM&hash=item1e6ff1161f
That lots not a bad selection. Clearly a bit of a rob from a mod program of some sort.
Edited by dangerous brain (see edit history)
4-03 4-04 countersink cherry max rivets should in theory cover most 2 sheet thick automotive applications. You would of course have to countersink the plastic so it sat flush. Drill size is 3.2mm or 1/8th inch, keep a decent edge distance of 7mm from the edge to the middle of the drilled hole and maintain a spacing of between 3/4" and 1" and you will have aviation grade joints ish.
hi mate
is that what these are?
[ATTACH=CONFIG]154643[/ATTACH][ATTACH=CONFIG]154644[/ATTACH][ATTACH=CONFIG]154643[/ATTACH]
No No and more NOOOO!! If you fit countersink rivets correctly you will never know they are even there!
By the looks of it our Craig is the man that can sort you right out with the rivets you need. Now you just have to hire the appropriatte equipment to pull em down.
You can get rivets that act as studs also, use them with anodised Allen bolts! ;)
Now you are on about Hi-Loks or Hi-Lites. You need access to the back of the job to put them in. They are extremely strong fasteners used when you are not expecting to have to remove the fastener as opposed to nuts and bolts when you may have to remove them for maintenance activity.
You want some pull up fasteners of some sort. The size of those fasteners is very large. That means you will need a very big gun to pull them up. Last time I checked guns big enough to pull that size fastener were massive prices. You can rent guns like that but again be prepared for some cost rapeage! You could produce a very similar effect by getting hold of the right sized Hi-Loks and taking the anodized coat off the collar and laquering the collars post fit.
