Ohm reading from Supra fuel sender.
a98pmalcolm
Hay guys bit of a strange question but I'm thinking of installing a custom fuel level gauge.
To set the fuel level gauge to read correctly you turn the switch to the correct ohm (Ω) value scale to match the rating of the vehicle’s fuel level sensor.
Does anyone know if any of these values are correct to the supras fuel sender?
http://img825.imageshack.us/img825/4588/80670006.jpg
Thanks
You probably need a "mappable" dash as the sender output on most cars is none linear, and matches a none linear meter movement. Ryan will know for sure re the MKIV sender, but a lot of stuff has been written on getting an accurate full range digi dash readouts from stock fuel tank senders in general.
